Break in Methods
Old Dec 30, 2008 | 10:48 PM
thendawg's Avatar
Default Break in Methods
So ill be finishing up my engine build and hopefully hearing that first breath of fire a week from saturday - so my question to you guys, what break in method seems to work the best? How many people stand by the famous motoman method?
Old Dec 30, 2008 | 10:59 PM
deathbyc4's Avatar
you just built it, why break it??
just drive it like a granny and get some miles on it. check the oil often since a new block will suck up some oil and seal the fine lines. That's mainly the deal but some would argue to do more than that.
Old Dec 30, 2008 | 11:00 PM
draxcaliber's Avatar
break in method or the engine or for the turbo or both?
when my tc was new, i just shifted very early all the time for the first 1k miles, shifting at 3 rpms sometimes 4 if i was in a rush, but never at WOT and so on.
when i had the supercharger installed, i again only drove it up to about 3k rpms for about 500 miles, then the next 500 miles, i slowly revved up to redline in 1st and 2nd gear to make sure everything was running smoothly and correctly through out the entire rpm band.
so far i haven't had a single problem.
Old Dec 30, 2008 | 11:02 PM
purplenitroustc's Avatar
____ty oil first, good oil later
Old Dec 30, 2008 | 11:03 PM
SoFloTC's Avatar
breakin in the motor.. i did granny style but let it go through the rpm band unconsistent ... dont highway drive
Old Dec 30, 2008 | 11:24 PM
B_Real45's Avatar
Just drive like a sane person.
Also, try not to keep it at a constant RPM for a long period of time - ie: highway driving at a constant speed.
Back when I had a Saturn, I built my motor but had to drive back to Gainesville FL for college, which was 6 hours away. I ended up taking the "backroads" filled with street lights. I ended up getting to school in 9 hours but my engine was being properly broken in!
Oh - and yes, conventional oil first few oil changes. Not "____ty" oil - but we know what purple meant.
thendawg's Avatar
Purple x2 on the oil As for anyone un familiar heres the link to the motoman breakin method http://www.mototuneusa.com/break_in_secrets.htm
Old Dec 30, 2008 | 11:28 PM
thendawg's Avatar
haha - also for priming the oil system - is it really required to push oil in through the oil sender tap using a pressurized container and schrader valve? Or is it ok to just crank the motor with the efi and plugs disconnected for 20-30sec 2-3 times to prime the system? Im no stranger to internal motor work but this is my first "modern" motor lol everything ive delt with you could prime using a drill with the distributor shaft lol - also was thinking what about filling it with oil and turning the crank by hand while still on the motor stand to prime it?
Old Dec 30, 2008 | 11:31 PM
B_Real45's Avatar
Yes turn by hand.
Old Dec 31, 2008 | 12:48 AM
crush02342002's Avatar
good luck with engine mang
Old Dec 31, 2008 | 06:27 AM
aen's Avatar
aen
motoman break-in.
yupinmytC
22
Jul 27, 2024 07:08 PM
rvascion
Nov 12, 2020 03:23 AM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
SoccerBoy_AP
Oct 1, 2015 06:28 AM
user9430961
Sep 15, 2015 03:16 AM
