My turbo car is throwing cel light code PO300 and 301
Old Dec 31, 2008 | 01:35 AM
Rydrdg's Avatar
Default My turbo car is throwing cel light code PO300 and 301
The Code is PO 300 and 301, Cylinder 1 misfire anybody have any idea what might of trigger this, any help or opinion would be greatful..
Old Dec 31, 2008 | 01:40 AM
purplenitroustc's Avatar
thats random and cylinder 1
check plugs first and report back
if u dont know what ur looking for take a pic of the plugs and post it
Old Dec 31, 2008 | 01:46 AM
TheFantasticG's Avatar
P0300: Random/Multiple Cylinder Misfire Detected
P0301: Cylinder #1 — Misfire Detected
Is there not a list of CEL codes on this forum?
Old Dec 31, 2008 | 01:47 AM
Old Dec 31, 2008 | 02:16 AM
crush02342002's Avatar
check your plugs, check your ignition map (rule of thumb 1degree of retard for every psi of boost...just a reference), im not familiar with greddy management so check your software and make sure your running whatever software that is best suited for the tc (if there is different software)
Old Dec 31, 2008 | 02:17 AM
also what are your afrs......that will deff help
Old Dec 31, 2008 | 02:18 AM
nope you need to post one huh
Old Dec 31, 2008 | 02:23 AM
Rydrdg's Avatar
its dark outside and cold plus tomorow will be a snow storm, maybe new year thursday I wil take a look
Old Dec 31, 2008 | 02:37 AM
Yes Chris, yes I do.
Old Dec 31, 2008 | 03:04 AM
t_urbo_C_harged's Avatar
how is it running? is it missing at idle or under load?? Check plugs, check spark, then check the flow of the injector.
Old Dec 31, 2008 | 01:57 PM
davedavetC's Avatar
idk how much you know but if you need a hand let me know im not far from lowell and i have the rest of this week off from school (but i do work).
Old Dec 31, 2008 | 02:17 PM
cessblood's Avatar
Check the injector, coil pack or the spark plugs. Try switching them around and see if the misfire move to another cylinder that will help you find out the cause of the missfire. I can stop by and help you if you want bro.
Also Davedave hit me up.
Old Jan 2, 2009 | 12:02 AM
Rydrdg's Avatar
I went to Cess house I switch the coil and reset cel now waiting to see if cel comes back then check it for codes
Old Jan 2, 2009 | 12:20 AM
hope it works out.....good luck
Old Jan 3, 2009 | 11:29 AM
Rydrdg's Avatar
no signs yet finger is cross
Old Jan 9, 2009 | 10:43 AM
Rydrdg's Avatar
Ok yesterday I got the Cel again and same code
Old Jan 9, 2009 | 03:49 PM
m6ar2cel6oTC's Avatar
it might be your tune just like me. atleast you got 2 i got 6 lol.
Old Jan 9, 2009 | 04:16 PM
CarbonXe's Avatar
Check your plugs. If they're fouled, then that's what is causing the CEL. But you can't stop there, because your tune is the thing that will cause the plugs to foul out.
Old Jan 9, 2009 | 05:15 PM
enjoithis's Avatar
99% sure its caused by tune. Post your AFR's
Does it stumble when it throws the code? Are you under boost, cruise, or idle?
Old Jan 15, 2009 | 10:41 AM
Rydrdg's Avatar
I change the plugs now it idle better, and so far no cel yet, I will give it another week of driving. afr for idle is 15-16-17 afr for cruising is 14-15 afr for boost is 11.2-12.3 at 8-10 psi
