Cigarette Power when car is turned OFF HELP
Old Dec 31, 2004 | 09:48 PM
chriscummings83's Avatar
Default Cigarette Power when car is turned OFF HELP
I want my Cigarette Lighter Port to be powered when I turn my car off. So if i have a cell phone plugged in, it will charge while the car is off. I have a 2005 Scion TC.
I was wondering what the safest way to do this would be.
Thanks.
Old Dec 31, 2004 | 09:52 PM
Sciond's Avatar
hardwire to your fuseblock to a constant hot source and use an inline fuse
Old Dec 31, 2004 | 10:45 PM
skybiker's Avatar
I left the factory outlet alone & added 3 additional outlets. I stopped at the local Earmark audio & bought a 4 position fuse block so each new outlet has it's own fuse. I have an '05 xB, and put 2 just above the floor in the center console, and 1 in the back hatch area, just below the access panel on the side.
This way, the factory outlet turns off with the ignition, all the others stay hot. I use them to charge camera batteries when I'm at a shoot. I bought the outlets from a local marine store... they have rubber dust caps attached, looks good when they're closed up that way.
Old Dec 31, 2004 | 11:06 PM
Eddieg's Avatar
Dat's a great idea sky...do ya have any pics??
Old Jan 1, 2005 | 05:36 PM
skybiker's Avatar
Didn't shoot any pics of that.... I'll try to get some this weekend...... Just finished replacing the tails with a set of the Helix smoked ones..... Man, do they look good!
Old Jan 6, 2005 | 01:36 AM
scionstamp's Avatar
of all the vehicles i've owned, i've never had one that the ignition kills the power to the cig. lighter. i want to power my gps unit there, but it gets switched off every time i turn my xB off. guess i may have to add the add'l outlets like you did. where on the fuse panel did you wire it in?
Old Jan 6, 2005 | 03:10 AM
skybiker's Avatar
I ran the wire directly to the battery.... I also plan on running a ham radio from the fuse block, and need to run off the battery to elimate the possiblty of alternator noise in the signal. I run a Garmin GPS on one of the outlets quite a bit..... Doesn't shut off during stops................
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
ScionRo
Jan 2, 2015 07:54 PM
cwong1001
Dec 3, 2014 03:30 AM
TheRedBox
Oct 8, 2003 04:25 PM
