squeaky brakes without brake pressure
Old Jan 11, 2009 | 11:52 PM
kuo34's Avatar
Default squeaky brakes without brake pressure
I did a search on the forums and couldn't find anyone with quite my problem, so here it is. I recently replaced my shocks and checked my brake pads while the wheels were off by pulling the caliper up (removing the lower bolt for the backs and the upper bolt for the fronts) and popping the pads out for a quick visual inspection. After reinstalling everything and retorquing to spec, I've been getting an awful squeal with the rear brakes. I can sometimes replicate it by turning the wheels by hand. It occurs intermittently with cold brakes and at low speeds. Once I get up to speed or the brakes warm up the squeal usually goes away. Sit at a light too long and the squeal is back.
Theories are abound, but I'm guess I managed to remove some of the lube on the pad ears/shims during inspection. The calipers and pistons looked okay, boots look okay, no pits or scarring on the pads/discs.
So that's my best guess, a sticking pad. Anyone else have a similar issue or know of any other cause for such a change?
Old Jan 12, 2009 | 12:13 AM
kileil's Avatar
You can still stop as good as ever, right? If so its likely just dust or the pads need to reseat again, get back in their groove as it were and are dragging a bit.
As long as it brakes well, take it out for a few hard stops to get everything set back where it wants to sit
Old Jan 12, 2009 | 12:44 AM
kuo34's Avatar
I'll give that a shot. Yes, braking is still even and firm. I'll try a few more hard stops, but I'm guessing a good cleaning and regreasing will do wonders.
yhwhdesign
Jun 11, 2021 03:34 PM
kmouse64
Sep 4, 2015 01:11 PM
kmouse64
Scion xB 2nd-Gen Wheel & Tire
Jul 22, 2015 10:13 PM
blackpearlTC
Jul 19, 2015 04:55 PM
