The truth about the code P0171..
Old Jan 13, 2009 | 08:26 PM
Crayola_G's Avatar
Default The truth about the code P0171..
I threw the Code P0171 a few times now, and iv seen a couple other on the forum who have thrown this code. P0171 is defined as (seeing OBDII code list) as System Too Lean Bank 1. But, what this really means is fuel pump = epic fail. mines gone now, and that's the reason.
The reason I think P0171 is a fuel pump code is because i was reading up on the parts catalog for our car in the maintenance section and it said when it comes time to mess w/ the fuel pump when removing it your car may throw Code P0171.
And this is not for installing a performance one this is simply for tinkering w/ the fuel pump.
__________________
Old Jan 13, 2009 | 09:19 PM
engifineer's Avatar
No, it means system too lean. Fuel pressure issues can be one cause of this.
The codes dont pertain to cause, they pertain to effect. Multiple causes can cause one effect (sometimes many concurrent causes.. and sometimes because of the systems reaction to other codes).
Old Jan 13, 2009 | 09:26 PM
B_Real45's Avatar
My P0171 was fixed by replacing the primary O2 sensor.
Throw that one in there.
Old Jan 13, 2009 | 09:27 PM
Crayola_G's Avatar
but possibility of it being a fuel pump is up there, yeah fuel pressure makes sense.
Old Jan 13, 2009 | 09:30 PM
crush02342002's Avatar
I've had P0171 once.......it was because of a crap tune....adjusted my O2 map...everything's gravy.
__________________
Old Jan 13, 2009 | 09:47 PM
engifineer's Avatar
Yep.. like I said, anything that can cause the car to run lean can set the code. The ECU has zero idea why it is lean.. only that it is lean and it continues to run lean when the ECU adjusts. The ECU in most cases only tells you what is out of spec.. kind of like telling the doctor what hurts. The good troubleshooting is what tells you why
Old Jan 13, 2009 | 11:30 PM
NVMyTc's Avatar
X2, I had the same issue
Old Jan 14, 2009 | 03:07 AM
aen's Avatar
aen
also could mean improper tuning, fuel trims.
Old Jan 14, 2009 | 10:33 AM
aen did you not read my post....lol
Old Jan 16, 2009 | 03:56 PM
Crayola_G's Avatar
for me replacing my fuel pump fixed this code...p0171 can be several things one being fuel pump.
Old Jan 19, 2009 | 11:19 PM
Crayola_G's Avatar
Never mind I'm wrong, I changed the fuel pump and the code returned.....it's O2 sensor fosho
__________________
Old Jan 19, 2009 | 11:55 PM
B_Real45's Avatar
There's a TSB on it on the 2005-2006 tCs. Stock O2 sensor may malfunction.
__________________
Old Jan 20, 2009 | 12:11 AM
Crayola_G's Avatar
can i roll up to toyota be like yo man fix it lol
u think thyll notice the boost lol
Old Jan 20, 2009 | 12:12 AM
B_Real45's Avatar
Nah - you're SOL there.
Old Jan 20, 2009 | 02:28 AM
Crayola_G's Avatar
i just replace primary o2?
Old Jan 20, 2009 | 02:32 AM
I think that's right Crayola...if it is the O2 sensor it would be the Primary O2.......good luck brethren
__________________
Old Jan 20, 2009 | 05:59 PM
engifineer's Avatar
Yep, second O2 is purely for CAT monitoring.
matrix_XB
Nov 12, 2012 07:30 AM
ElevationTC
18
Apr 4, 2009 04:16 AM
RSracer
Mar 11, 2009 11:49 AM
ALEXB06PR1
Jan 11, 2007 11:45 PM
Munch
Nov 9, 2004 01:46 AM
