Supercharger PSI levels, whats normal?
Old Jan 18, 2009 | 02:46 AM
AZGuy's Avatar
Default Supercharger PSI levels, whats normal?
Well I just installed a boost gauge finally on my TC. Getting ready to slap the 9.5 pulley on but want to know what is normal for the stock SC setup with boost levels.
I have read 7 PSI is the max boost with the stock pulley but after a day of driving under heavy driving the most I have seen is 5 PSI and MAYBE touching 6 PSI. Under normal driving 2-3.5 rpm I don't see my boost gauge go above 0. I am still learning what is normal when it comes to forced induction and want to know what I am seeing is normal or if I need to fix something before I put the small pulley on.
If I am maybe leaking somewhere, where should I look/test for leaks?
Any info would be appreciated.
Old Jan 18, 2009 | 04:29 AM
HEYitzMEEE's Avatar
Look for leaks in your exhaust, vac lines etc. Other than that, switch out your Bypass valve. The stock one sucks more than a cheap hoe.
Old Jan 18, 2009 | 04:31 AM
NVMyTc's Avatar
You wont see 7psi until your almost at the redline, your setup is fine
Old Jan 18, 2009 | 05:13 AM
HEYitzMEEE's Avatar
^ the setup itself is fine. But we don't know if everything else on the car is fine. BPV sucks, belts might slip for some reason, there might be a leak somewhere etc etc. Switch out your BPV and I guarantee you'll see 7PSI RIGHT at redline as stated above.
Old Jan 18, 2009 | 05:14 AM
AZGuy's Avatar
Thanks, already put the forge 007 on in prep for the smaller pulley.
Old Jan 18, 2009 | 05:16 AM
HEYitzMEEE's Avatar
And you're still not seeing 7 @ redline? You must have a leak somewhere then... you should see it for a second before you shift lol.
Old Jan 18, 2009 | 05:42 AM
streettimetc's Avatar
if i rember the forge is adjst. with diff. springs rating i have the bosh 110.
Old Jan 18, 2009 | 05:51 AM
HEYitzMEEE's Avatar
Yes forge comes with 2 springs, green and blue i believe. i was using the blue spring with 1 shim that they provide. Worked good to get me to almost 10lbs
Old Jan 18, 2009 | 03:14 PM
AZGuy's Avatar
Hmm I'll have to pull out the BVP and play with the springs then. Where else could I be leaking if I am leaking?
Old Jan 18, 2009 | 05:37 PM
gompka's Avatar
Ideal max is 7psi doesn't mean you will hit that. I was seeing about 5-6 psi stock and they said that was normal when i talked with trd.
Old Jan 18, 2009 | 06:32 PM
AZGuy's Avatar
I found the problem, my cap on my forge 007 had a small leak, needed a little more tightening. Guess you need to check those even when brand new. I swapped out to the blue spring with one spacer while I was at it. Took my car out and hit 7 PSI at high RPM. Pays having a boost gauge to check that.
Old Jan 19, 2009 | 06:32 PM
g2autosports's Avatar
I'm getting 7PSI every single time I hit, I have the forge 007 BPV thou.
Old Jan 20, 2009 | 06:09 PM
gompka's Avatar
dealership FAIL once again. thats why i'm never taking my car in there again unless something really f'ed up happens with something non engine oriented.
Old Jan 21, 2009 | 12:09 AM
WESt-ICE-013's Avatar
sorry if this is discussed somewhere, but should our S/C be used with BPV as opposed to BOV's?
TBH im not too sure what the difference is.
brett561tc
Sep 15, 2015 06:33 AM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
mc1114
Aug 12, 2015 02:07 AM
Subaru86
Jul 31, 2015 04:33 AM
sgetchius143
Jul 28, 2015 09:55 PM
