Start up fuel trim, F/IC
Old Jan 20, 2009 | 12:06 PM
CarbonXe's Avatar
Default Start up fuel trim, F/IC
My car has been taking a pretty long time to start, mostly because it's been 5-10 degrees outside in the morning and it's starting to annoy me. I was just wondering how much fuel you guys are pulling for start up. I believe it's the 0 RPM/14 LOAD box in the fuel map. I've tried a bunch of different values and nothing is really making a difference. And my plugs are fine.
Old Jan 20, 2009 | 02:59 PM
paul_dezod's Avatar
Scionetics
KAD
Default Re: Start up fuel trim, F/IC
The FIC will take a sweep through the 14 PSI cell and sweep through to the set idle cell, which will be somewhere around 5-8. It takes a weighted cell average of those and slightly alters the cold start enrichment tables as a result. I have whitnessed this personally a few customers cars. Simply add a small % of fuel to those cell effected and see how it works on starting.
Old Jan 20, 2009 | 03:23 PM
CarbonXe's Avatar
Got it working better. I was pulling a little timing for that initial 14PSI LOAD block and that seemed to have been throwing it off. Once I changed that back to 0, it started firing right up.
paul_dezod's Avatar
Scionetics
KAD
Great!
Old Jan 20, 2009 | 03:24 PM
Ace83's Avatar
Ronin Scion
yeah generally a car needs more enrichment especially on very cold start up.. try add some enrichment on 0-1000 rpm on somewhere on the idle area
Old Jan 20, 2009 | 03:26 PM
CarbonXe's Avatar
I found it was harder to start with more fuel. I'm at -52% to -54% for idle, and so far, having that initial start block at -63% seems to work out the best for me. I messed with my tune and pulled some more timing the other day and didn't realize that I changed the entire row rather than just in boost .
Old Jan 20, 2009 | 03:46 PM
Ace83's Avatar
Ronin Scion
check your ignition too on the scangauge, idle should be around 7 to 15 ideally
Old Jan 23, 2009 | 01:39 AM
Pecka13's Avatar
crap i need to do this too....on really bad days the engine would turn over like 6 times before it started. thank god its getting warmer and a summer job will definately pay for a lot of crap
mw1957
Mar 16, 2015 06:00 PM
yhwhdesign
Mar 7, 2015 02:01 AM
mav261
Feb 11, 2015 02:43 AM
cid_mcdp
Jan 5, 2015 02:45 PM
eric_m
79
Mar 17, 2013 12:21 AM
