New headunit: What's causing this buzzing sound?
Old 01-24-2009, 11:24 PM
DJrepresent's Avatar
Default New headunit: What's causing this buzzing sound?
I installed a new headunit and notice that when switching songs or radio channels a strange high pitched buzz comes through either the speakers or headunit. I don't know how to narrow this down. I took it to my shop and they conducted a test with a multimeter where they touched one end to the ground terminal on my amps and the other end to the door latch and seat rails and the reading came out to 0.00 (however, the stereo wasn't turned on).
I don't know if this should still be investigated with the amps or if the headunit is messed up. Also, the amplifiers' power cord runs in the same conduit as the speaker RCA cables.
Any ideas?
DJrepresent is offline
Old 01-25-2009, 05:09 AM
TerribleTed's Avatar
The power and sound feed wires should not run together. It is possible that you are getting the noise from that.
TerribleTed is offline
Old 01-25-2009, 09:57 AM
buickid's Avatar
Does this sound happen when you're switching songs? Does it happen when theres nothing playing, but the volume up as well?
buickid is offline
Old 01-25-2009, 10:00 PM
I happens at random times, or at least I notice it at random times. Yes it happens when switching songs and the volume needs to be up.
Any ideas?
Old 01-26-2009, 01:42 AM
buickid's Avatar
If theres nothing playing, but you turn up the volume, does it buzz? It it continuous or intermittent? Try disconnecting the RCAs at the amp and see if it still makes this buzzing noise.
buickid is offline
Old 01-27-2009, 11:52 PM
Slody4Futbol's Avatar
is it a pioneer radio? reground everything and do not disconnect or unplug the rca's while the radio is on
also take a piece of 14-16 gauge wire.. ground it to your radio, and run it to the ground on the amp
Slody4Futbol is offline
Krysune
04-30-2015 02:25 PM
GoodVibes
03-10-2015 04:29 AM
idriveanxa
03-08-2015 12:03 PM
corbmonster
01-24-2015 05:22 PM
CBSIMONSEZ
29
01-02-2004 09:57 PM
Quick Reply: New headunit: What's causing this buzzing sound?
