Launch Control **Un-Advertised E-Ultimate feature**
Old Jan 25, 2009 | 01:01 AM
rhythmnsmoke's Avatar
Music City Scions
Default Launch Control **Un-Advertised E-Ultimate feature**
Call me ignorant up till now, but I have seen the light. An UN-advertised feature on the Emanage Ultimate....2step launch control.
No WotBox, no Full Standalone....Emanage Ultimate has it. Saved me $200 bucks from needing to buy the WotBox.
Simple as apple pie to setup, cause all you do is type in numbers. I can't fully engage it yet as the car is not tuned, so when I hit the 2 step, it bogs and cuts off (un-tuned). So, when I get the tuning bugs worked out on it, it will be good to go.
Old Jan 25, 2009 | 08:31 AM
NVMyTc's Avatar
Does it have ignition/fuel cut so you can WOT shift?
Old Jan 25, 2009 | 11:00 AM
Music City Scions
Yes, ign cut. Not fuel cut though. For WOT shifting, I believe it needs to be hooked to the clutch switch. I have not got that far on it yet, in my setup. Been doing mostly research and asking other car makes who are using it.
Old Jan 25, 2009 | 01:23 PM
Music City Scions
89 views, one reply. You guys don't like launch control or something....hehee.
Old Jan 25, 2009 | 01:36 PM
chintastictc's Avatar
how do you get to it?
Old Jan 25, 2009 | 01:40 PM
Ace83's Avatar
Ronin Scion
and flat shifting to right? good find..
Old Jan 25, 2009 | 02:04 PM
Music City Scions
Yes, it's called Ignition Cut Settings, located on the IGN tab in the Parameters Section (little car icon).
The box for "Shift UP" is for WOT shifting. The Start RPM is for what you want to launch at. The IGN Cut RPM box is basically whatever your redline is set to. Your "Shift UP" number has to be lower than your IGN Cut RPM setting.
I will try and get it setup more and try to get some vid or something.
Also from my understanding, the 3 boxes (Start RPM, IGN Cut RPM, and Shift Up), have a check box next them. If you check either of those boxes or all of them, they will correspond to the Timing adjustment number listed in the box below called "IGN Adjustment".
IGN Adjustment adjust the ignition timing so that you can actually spool the turbo during the 2 step.
Old Jan 25, 2009 | 02:08 PM
NotAStockScion's Avatar
if u ever have downloaded the tuning software its right on there in plain sight
once u post a video im sure u will get more reviews
also that sciongt35r posted about it in his monster thread
Old Jan 25, 2009 | 08:06 PM
NVMyTc's Avatar
These people just dont know what they are missing lol
Old Jan 25, 2009 | 08:20 PM
Music City Scions
^^No kiddin. I tried the 2 step a little today. I have it set at 3k rpm. When I did it, it thru a CEL. I assume it's for Mis-fire. Anyone get mis-fire cel when the launch control hits. What about the WOTBox users? You guys get a Cel uning the 2step on the WOTBox?
Old Jan 25, 2009 | 08:32 PM
SoFloTC's Avatar
u dont have a cel anyway?
Old Jan 25, 2009 | 09:30 PM
aen's Avatar
aen
i'd expect a misfire code from 2step man.
Old Jan 25, 2009 | 09:45 PM
YEH THE WOTBOX MAKES MY CEL FLASH LOL
Old Jan 25, 2009 | 09:51 PM
Music City Scions
No, I'm cel free. I was cel free on the Blue box, and also Cel free on the Ultimate + Blue box (yes, I'm running dual management, however only the Ultimate is controlling the car). Blue box Cel table is all zeroed out.
Old Jan 25, 2009 | 09:54 PM
Music City Scions
Yeah, I know. I was just wondering if it happens on the Wotbox, as no one mentioned it thus far.
Just flash? Or does it stay on after you come off the 2 step?
Old Jan 25, 2009 | 10:19 PM
aen's Avatar
aen
yea it does i think... olahalo has a misfire code again i think. haha
Old Jan 25, 2009 | 10:33 PM
Ace83's Avatar
Ronin Scion
yeah wot box users get cels i've heard.. and java too
Old Jan 25, 2009 | 10:35 PM
aen's Avatar
aen
flashing is NOT good, that means it's more than emissions related.
Old Jan 25, 2009 | 10:42 PM
it throws a misfire code
Old Jan 25, 2009 | 11:19 PM
no not entirely true when a cel flashes its telling you that damage to the cat can result from the code that it is currently throwing..thats what my toyota instructor said about flashing CELs....and travis it flashes and then goes away...and if you do it a couple more times it will flash and then stay there...i clear my codes every two days lol
