Self-Tire Rotation help
Hey guys, I know this is probably a noob question.
I rotated my tires from back to front on my 09 scion tc. Now the car is making poping sounds as i drive, as of somthing is loose. Do I have to Cross Rotate my tires ? Is anyone aware of this ?
you dont need a torque wrench...just use the one that comes with the car until you cant tighten anymore...by that i mean you really should put weight on it, not just hand tight.
and arnt you suppose to cross rotate...not just rear and front swap on same sides?
The owners manual says to just rotate rear to front on the same side. I believe the oem tires are directional. Defiantly try to tighten them up but over tightening is not good either since you can warp your rotors, but I did it without a torque wrench before I had one and I didn't have any problems.
At least buy a cheap torque wrench.
That's a great way to strip the lugs when you try to loosen them...
im not saying freakin put the bar on the lug nut and jump on it or anything, just tighten to what you "feel" is right.
I can tighten to over 120 ft lbs very easilly with the wrench that comes with the car, and I am no body builder by any means. 76 ft lbs is not nearly as tight as most think it is. My tq wrench is obviously longer than our stock lug wrench, but not by a huge amount. My son could put 76 ft lbs on a lug with it when he was 10 years old without straining.
I have tightened plenty of wheels without a tq wrench until I could get the car back home. But if you dont know what the correct tq feels like to some extent, you can get it too tight easily.
And it isnt just so you dont strip the lugs or break the studs, which an overly tight lug can do in no time. The idea is to get all the lugs the same. This is especially true on alloy wheels and/or disc brakes. If your lugs are unevenly tightened, you can end up with warped rotors and even warped rims over time.
TQ wrenches are cheap and a great tool to have around even if you do minimal work on a car.
