PCM processor fault
Old Feb 2, 2009 | 07:44 PM
gingles's Avatar
Default PCM processor fault
not sure if this is the right spot for this topic or not.....i read my codes today and came across this one.....i researched and it seems to have something to do with the secondary o2 alot of times.....well...im not running any o2's so i can tune partial throttle......its raining today and was thinking maybe some water got into the connector and maybe crossed the wires or something....not to sure but was wanting some more input...im also running a blow thru maf setup...not sure if that as anything to do with it but hey every little bit of info helps.
Old Feb 3, 2009 | 02:12 PM
toyota_scion_tc's Avatar
I had that code when I used o2 sim on the secondary o2 sensor. Could be map or you o2 sensor plugs grounding out on something or just a bad sensor i.e. maf.
Aroxguns
Mar 20, 2015 10:06 AM
spikeymike78
Sep 25, 2005 12:09 AM
nycazn79
Apr 18, 2005 06:23 AM
Nathant888
30
Sep 3, 2004 06:49 PM
whippets2
30
May 26, 2004 02:35 AM
