New engine build (HELP NEEDED)
Old Feb 5, 2009 | 04:36 PM
HEYitzMEEE's Avatar
Default New engine build (HELP NEEDED)
So if you guys don't already know my problem, my supercharger crapped and blew my motor kinda. ( https://www.scionlife.com/forums/vie...763&highlight= ) My motor is still running, but heavily on the verge of blowing. Compression numbers are around 80 across every cylinder.
This is the second supercharger to mess with my engine and i'm not going to waste my money anymore! (eff trd ftw). (Oh I will be selling the kit with a brand new seal so you won't run into my problem).
Anyways, I have to get a new block and i'm getting an 05-06 block and figure i'm going to rebuild this block. My power goals go as 370 WHP approx. What would you guys recommend that I get to keep this car RELIABLE? I know the power is high and to ask for reliability is ridiculous, but let's see where I can go and still be safe. What internals do you think would be best to beef the engine up??
Old Feb 5, 2009 | 04:46 PM
thendawg's Avatar
Im gunna be parting out a build motor soon Look for parts in the fs section this afternoon
Old Feb 5, 2009 | 04:47 PM
HEYitzMEEE's Avatar
Oh really! Haha. I'll have to take a look. Hope no ones buys till I get my federal tax return back.
Old Feb 5, 2009 | 08:44 PM
HEYitzMEEE's Avatar
Anymore advice? I know there are a few built tC's out there!
Old Feb 5, 2009 | 09:19 PM
Guru's Avatar
Just rods, pistons, ,main and head studs. New ACL bearings and you'll be fine. 400 WHP is not much.
Old Feb 5, 2009 | 10:09 PM
HEYitzMEEE's Avatar
Okay great. I'll take a look into all of those and see what it would cost me. 2 failed superchargers and 1 failed motor is enough to make me rebuild one.
Old Feb 5, 2009 | 10:40 PM
HEYitzMEEE's Avatar
As far as the size goes, standard size would be more appropriate?
Old Feb 5, 2009 | 10:56 PM
thendawg's Avatar
I posted everything for sale - check it out
Old Feb 5, 2009 | 11:00 PM
HEYitzMEEE's Avatar
I saw haha. I want to make some offers, but I am still waiting for my income tax return to get here! Right when I get it, im blowing it all on motor parts! I need a 400 whp tc! haha
Old Feb 6, 2009 | 12:49 AM
crush02342002's Avatar
good luck!!!!
Old Feb 6, 2009 | 01:27 AM
HEYitzMEEE's Avatar
Haha thanks. This is definitely going to be something different lol. Should i stick with standard bore on everything?
Old Feb 6, 2009 | 02:29 AM
HEYitzMEEE's Avatar
And another question. I highly doubt i'll be able to get the turbo kit on with everything else. If I run with the upgraded pistons, rogs, valves etc, I'd have to get my car tuned correct?
Old Feb 6, 2009 | 10:30 AM
if you go with lower compression or higher compression and even larger pistons id say yes your gonna need to tune for it to get the most out of the set up. larger valves could benefit from a nice tune as well. is it a must in order for the engine to run i wouldn't think so, but it may not run very nice though so might as well bank on getting some form of engine management. if you stick with stock dimensions and compression then no you wouldn't need engine management but what fun would that be??!!
Old Feb 6, 2009 | 03:00 PM
HEYitzMEEE's Avatar
Haha i'm just looking for something that can withstand more power than stock. What's the benfit of increasing the bore? Wouldnt I have to bore the block as well?
Old Feb 6, 2009 | 03:01 PM
purevision01's Avatar
^^ agreed^^
Is this going to be an N/A build or building the motor now and going turbo/nitrous later. If N/A, Mahle makes a light weight rotating assembly for the tC, remove the balance shaft, and bumping up the compressiong will be the only things to make power on the bottom ending, As for the head, larger valves, port and polish, cams and intake manifold is a good start. Make sure if doing port and polish, you get it to a flow bench and make sure you didnt reduce airflow. Right now there is only really one cam on the market (brian crower ewww lol) but if you can wait a little while Ptuning has a cam in development (not sure who they are working with on this) and I am trying to work something out with Kelford. IHE blah blah blah you know the rest and top it off with a tune.
For turbo apps, get yourself a gt30/35 bb or non bb or equivalent sized turbo, 750cc injectors, head gasket, 9.5/9.0-1 pistons from CP, mahley or JE, acl or cleavite bearings and make sure you include the thrust bearing, Supertech dual valve springs and retainers (bcuz thats what I use), walbro 255lp (may have to add a return line depending on your tune), ACT clutch to hold it all together, about 18psi should definitely net atleast 380whp if not damn close to 400whp. If you run out of fuel before making 400whp with the above, you will definitely have to bump up to a fuel rail and return line setup.
Old Feb 6, 2009 | 03:35 PM
HEYitzMEEE's Avatar
This is going to be a turbo build (What I should have done a long time ago instead of EVER messing with the supercharger). Right now, I have my eyes set on K1 H-Beam Connecting Rods, Wiseco 9.0 pistons w/ rings, Cleavite bearings (from dezod) w/ Thrust +washer, head gasket :O, and I have to do some more reading on the turbos. I've been SC forever and know almost nothing about Turbo's lol. DD I want to expect about 350 whp. If I ever track the car, I want to be able to run 390-400.
With a supertech spring kit and some black nitride valves (std bore), what would I be able to raise my limiter to safely?
Old Feb 6, 2009 | 04:27 PM
m6ar2cel6oTC's Avatar
60-1 turbo FTW!
Old Feb 6, 2009 | 04:43 PM
HEYitzMEEE's Avatar
Haha yeah. The turbo is going to have to wait a while though. My main concern at the moment is getting the internals inside the extra block that i'm going to buy. After my built block is running smooth in my car, IM GOING turbo this time. Eff SC'ers forever. So with a motor being built, I know I can run a little more than 10 PSI.
Old Feb 6, 2009 | 05:05 PM
with full valve train you should be able to rev to 8k rpm on stock cams no problem.
Old Feb 6, 2009 | 05:06 PM
You can check this link for a video of my car shifting at 8K
http://www.youtube.com/watch?v=jqxfod52gPk
