Relocated Fuse Box?
Old Feb 8, 2009 | 10:20 PM
oilpanman82's Avatar
Default Relocated Fuse Box?
Anyone who has relocated/moved the fuse box can you please give me some guidance
thanks you
Old Feb 9, 2009 | 12:00 AM
yellowxhoodie's Avatar
unless you want to extend and test every single wire...
the only place it will really reach is down below the stock battery mounting position.
and even then its gonna take alot of harness splicing and re-wrapping, not to mention it will be exposed to water even more unless you make some kind of waterproof box for it.
Old Feb 9, 2009 | 12:11 AM
kagenokaze's Avatar
I don't see much benefit in this ??
Old Feb 9, 2009 | 12:20 AM
it looks nicer.
Old Feb 9, 2009 | 04:49 AM
you did it yellow? you have any pics?
it does look like a LOT of cutting and splicing
Old Feb 9, 2009 | 05:05 AM
aen's Avatar
aen
what would you have to splice? why would you have to splice? i dont' understand..
are you transferring voltage of one wire to another wire?
aen's Avatar
aen
also, it's much easier to extend the wires than splice them.
Old Feb 9, 2009 | 05:58 AM
you dont have to splice the actual wires, u just splice the tape holding all the wires together and then figure out a way to re-run everything.
OP, yes i did it. check my thread. the links in my sig.
Old Feb 9, 2009 | 10:26 AM
I meant extending not splicing
I better go buy some electrical tape
... so I just have to re-do the tape not extend any wires to move it down a bit
Old Feb 9, 2009 | 10:35 AM
davedavetC's Avatar
how about some solder and heat shrink
Old Feb 9, 2009 | 10:59 AM
I always solder.. I just assumed that was implied sorry
Old Feb 9, 2009 | 12:00 PM
aen's Avatar
aen
i was about to say! splice into what! haha, i'm doing mine today, i'll take pictures for you.
Old Feb 9, 2009 | 02:04 PM
its still gonna be slightly visible.
if you want it completely out of sight then youll def need to extend wires.
Old Feb 9, 2009 | 02:51 PM
Not trying to move it for looks.. Would like to move it down so i can fit an intercooler behind the headlight.
That would be much appreciated aen looking forward to it
Old Feb 9, 2009 | 04:44 PM
this is as far/low as your gonna get it forward. you could always try moving it back under the Clutch Fluid Reservoir.
Old Feb 10, 2009 | 01:56 AM
nice!
bump for anyone els
Old Feb 10, 2009 | 03:31 PM
im the only one. lol
Old Feb 10, 2009 | 04:27 PM
BZinn1's Avatar
dang you were really able to move it quite a bit huh.
Old Feb 10, 2009 | 04:31 PM
yea but it wasnt easy.
and i have had some problems (as you already know) that may or may not be associated with it.
Old Feb 10, 2009 | 05:59 PM
What problems?
