View Full Version : Passenger window not working AND I KNOW I DID SEARCH!
jamessicat25
02-13-2009, 03:45 AM
I recently installed my component speakers with my friend's help and he did unplug most of the wiring under the dash. So after I put everything back, plugs, etc. My passenger side is uncontrollable from the driver side, the lock button works but the window can only be opened at the passenger side.
After i did that tutorial on resetting the windows and sunroof, driver side works with 1 touch but passenger is still uncontrollable, i have to push it on the passenger side control to open it. I DONT UNDERSTAND WHATS GOING ON!? help please?
and yes I did search.
EDIT: even after doing that resetting, passenger 1 touch don't work! and I just noticed that the button is blinking
kumquatism
02-13-2009, 03:56 AM
i had this same problem too, twice. i dont know what happened, but somehow it got solved on its own after a couple days or so.
tagging, for future reference in case i encounter it again
yellowxhoodie
02-13-2009, 04:05 AM
i never even bother re-setting mine, just wait a couple days and it will reset itself.
jamessicat25
02-13-2009, 04:06 AM
its been 2 days...
yellowxhoodie
02-13-2009, 04:07 AM
lol, well have you unplugged the battery again at all?
give it 2 more days.
if they still dont work by then, then id say take the door panels back off and make sure everythings connected.
geo46_2
02-13-2009, 04:11 AM
this happens to me when i disconnect the battery, drivers side passenger window button dont work, but the passanger does and my sunroof dont work either lol, i think ive had these for about 3 weeks. ill take it to the dealer and see what they tell me. i havent reset anything either since i dont know how to do that.
yellowxhoodie
02-13-2009, 04:14 AM
well then you should prob look it up.
your gonna waste your time going to the dealer because they just gonna,
A.) tell you to reset it
B.) do it for you and prob charge you
HEYitzMEEE
^ lol. when you disconnect the battery, you have to hold each window button for 3 seconds to activate the controls. When activating the controls, you have to use the respectable side. Ex: Driver window, use the window lock on the driver side, passenger window, use the window lock on the passenger side.
geo46_2
02-13-2009, 04:16 AM
ok does that affect my sunroof aswell, and if it does will this fix it too?
HEYitzMEEE
02-13-2009, 04:19 AM
Yes it does. The motors have to reset and relearn their positions.
geo46_2
02-13-2009, 04:21 AM
ahh ok dam this is so simple, i should have asked. thanks :P
HEYitzMEEE
02-13-2009, 04:23 AM
Np lol. I didn't know either till I got ____ed and pushed the window button as hard as I could then it moved. Lol..
jamessicat25
02-13-2009, 04:24 AM
I did all the steps on that resetting thing nothing works I DID IT FOR 5 TIMES
My sunroof auto opens and my driver side window does the 1 touch but the passenger is NOT WTFFF
dave2610
02-13-2009, 04:25 AM
100% correct you have to do each one on its respective side same for sunroof
HEYitzMEEE
02-13-2009, 04:26 AM
^ Lol what would the respective side on the sunroof be? :-P
geo46_2
got it thanks guys.
ahatch133
02-13-2009, 04:36 AM
if mine didnt "reset" real quick i chirped the tires a little bit lol went around my neighborhood threw it in reverse and then it worked lol so idk
HEYitzMEEE
02-13-2009, 04:38 AM
LOL^. I guess harassing your car will also force it to operate correctly based on the above statement.
yellowxhoodie
i guarantee you that has nothing to do with it.
O5_TRD_tC
02-13-2009, 07:13 AM
This happened to maybe once, out of all the local LED swaps ive done. All I did was unplug the passenger switches for 30 secs and replugged them back in and it worked again.
svencarlson07
02-13-2009, 07:05 PM
this happens everytime i unplug the battery for me...it randomly works after 3 days
