how do i FOG LIGHT???
Old Feb 19, 2009 | 06:20 AM
JDMxbB's Avatar
Default how do i FOG LIGHT???
sup fella's
i just want to manually switch constant ON the FOG LIGHTS by it's switch.
so for example.
i want to drive without the headlight's being on but off.
but i can turn the FOG LIGHTS on manually.
or have the fog lights's on with the headlights as well. when desired.
how do i do that i seen that thread somewhere but
now i can't find it. please help.
thanks for your patience.
Old Feb 19, 2009 | 06:22 AM
EAmon's Avatar
there is a write-up on this... you should search for it
Old Feb 19, 2009 | 07:57 AM
enjoi's Avatar
I'll be a nice guy
https://www.scionlife.com/forums/viewtopic.php?t=213884
Old Feb 19, 2009 | 11:43 AM
ack154's Avatar
I love how "fog light" just became a verb. Awesome.
Old Feb 19, 2009 | 12:45 PM
xBHAWK's Avatar
Default ....HELPFULL TIP....
I used this DIY to get hot switch control of my foglights.
Easy tip, mentioned in that thread after the DIY, just ground the switch and it will work the way you want them to. But will not 'alarm' when you turn the car off and open the door.
Old Feb 19, 2009 | 02:59 PM
burstaneurysm's Avatar
I thought it was a new dance or something.
Old Feb 19, 2009 | 03:12 PM
Skuff_Box's Avatar
*added Fog Light to his vocabulary as a verb......
Old Feb 20, 2009 | 07:55 PM
greenguyshrek's Avatar
The simple mod:
http://members.***.net/inazuma/fogs.htm
Just clip the black wire and ground the end coming from the switch. This makes the fog lights come on any time the switch is on no matter what else is on or off, what the state of the headlights, key, or even with the car off. The downside is that if you don't flip the switch off when you stop the car they will stay on and drain the battery. Also if you don't remember to turn the switch on they will not come on when you get in the car. . That is why I did it with the relay.
The mod using the relay:
https://www.scionlife.com/forums/vie...t=foglight+mod
Taps into some switched 12v source (I used the parking light 12v) to run the relay control, the relay contacts connect the black wire of the switch to ground when the relay is powered. Doing it this way turns the fog lights into "running lights" that come on when the key is on - but you can still switch them off using the fog light switch.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
