View Full Version : Conservative Modification?
Workbox
01-22-2004, 01:51 PM
I'm the guy that this car is not made for (age wise), but I just find this car with so much utulity. It saves gas, it's big, I can haul stuff in the interior, it's functionable, and I have it on order. But my question is that I want to modify it with an intake and exhuast sytem, but want to keep it with minimal noise, but still want the power for freeway traveling here in Houston Tx. I'm looking at the injen and AEM and TRD exhuast. I know that the injen is good, but is it loud? Can any you young experienced guy's help me recommend a system set up?
dinkjs
01-22-2004, 02:49 PM
Either one is fine.....plus intakes arent to terribly loud....that make a slight growl sound when you get on it from the air being pushed through....exshaust eh look around on that topic....its always coming up you will find plenty of research info on that topic
1NZFE
01-22-2004, 03:04 PM
Keep it stock.The AEM intake wont do much (slight increase in noise).
The TRD exhuast is too loud. From your Avatar you have a child, so that exhuast is too loud and pointless to have on since the xB is underpowered. Kinda embarrassing when your idling loudly at a light when you only have 108hp/105 torque at the flywheel...IMO.
Also, most/all high flow exhuast system/muffler (including TRD) will decrease the amount of torque it has. You need torque to really keep moving in all situations, IMHO. Have you driven an xB before? The engine does make a bit more noise (pleasant rumble) compared to a, let's say a Camry.
Cameron
01-22-2004, 03:07 PM
The complaint with the TRD exhaust seems to be the loss of some low end power. I've never heard or experienced any after market exhaust myself, but have been doing research on the topic. As far as intakes go, I have the AEM and am installing it this weekend. It's very expensive compared to the short Ram's that are out there (Injen and SPFR besides others), but it's a solid unit.
One older guy sold his TRD exhaust for making too much noise...here's more on that... http://www.scionlife.com/forums/viewtopic.php?t=4896.
He got $100 for it. If you'd like, I'll buy your TRD exhaust for $100 if it's too loud for you :D .
The axelback/catback exhausts generate more power, but I don't know how they compare to TRD in sound.
bBted
01-22-2004, 03:11 PM
trd is loud when u r in the car...
Workbox
01-22-2004, 03:25 PM
Thanks for the replies. So Basicly, I just need a good intake and no upgraded muffler? If so, between injen or AEM?
Cameron
01-22-2004, 03:36 PM
Flip a coin.
Fitment issues with Injen, but slightly more HP/Torque. $165 or better. http://www.adventon.com/acb/showdetl.cfm?&DID=24&Product_ID=16807&CATID=230 (best price on the net)
Here's more on the issue http://www.scionlife.com/forums/viewtopic.php?t=5420&highlight=injen
AEM is offered as a factory option, but more expensive $280 from an after market shop. Refined looking piece. http://www.scionlife.com/forums/viewtopic.php?t=1861 for more info. Take a look in the store on this site under "intakes" to check out other options.
The only reason I'm running AEM is because I like the look and I got it for $160 from a private party.
Workbox
01-22-2004, 04:04 PM
Ok, Houston is basicly a controlled swamp and we have alot of flash floods and I know that the AEM has a specific valve for incidents of high water. Does the injen have the same system?
Cameron
01-22-2004, 04:19 PM
Someone correct me if I'm wrong...
The Injen is a short ram intake and the filter is located near the fog lights. It is well protected from water intake and should not require a flood protection valve.
The AEM filter is going to be a lot lower than the Injen intake, thus, the valve.
scionracerxb
01-22-2004, 04:39 PM
well, i guess you have never heard or ridden in a car with the trd exhaust in person, cuz i have it on mine, and it is the quietest exhaust that i have heard, it only gets loud if you give it wide open throttle, and it DEFINATELY is not loud just sitting at a stoplight. As a matter of fact, 2 times now i have accidentaly hit the starter when the car was already running because its so quiet! And if anything, it gives it more torque. :shock:
Workbox
01-22-2004, 05:04 PM
Have riddin one with all the dealer upgrades at the dealer ( AEM and TRD combo) and it sounded not to noisey. But did ride both a regular stock and upgraded and could tell the difference in power.
debris
01-22-2004, 05:18 PM
the injen intake is right behind the the light.....fittment on mine was cake.
the only problem is the battery sits real close to a sharp piece of metal that is bracing the intake...but sounds awesome and gives great power.
i have a son and its not loud at all for him.
raiden1200
01-22-2004, 05:33 PM
is that sharp piece bracing the intake a problem then? if it is, is there anything that can be done?
thnks
1NZFE
01-22-2004, 05:48 PM
I used to have a TRD muffler on my car. It was made by Borla, sold as a TRD part. I know at cruisin highway speeds, at least on that one, the noise (or lack of) is similar to stock. But during summer months, when i would use my A/C and at a light it would rumble nicely. Probably an underpowered A/C on my car. :cry: :cry:
Maybe the xB version is different, so I wouldn't know. :?
Links for East Coasters for Scion parts when available. Save you on shipping too i think. Sometimes they have sweet deals.
Located in PA
http://www.partznet.com
Located in NC
http://www.toyotaparts4u.com
Scionic
01-22-2004, 05:55 PM
thnks
yeah that was one of the complaints on the injen intake when I installed it in the shootout. You can pretty much shave it down or file it down.
Aside from that I have no complaints....it makes good power which you can feel even if it isn't worth it according to 1NZ-FE. I say anything that can help the engine should go on.
As for your concern on hydro-lock the Injen Short ram sits the highest up compared to all the intakes that I dynoed. Interesting huh considering that it yielded the best results.
Anyway, none of the intakes made annoying noise....if anything it they all gave the box a little growl.
1NZFE
01-22-2004, 06:17 PM
IMHO :lol: :lol: :wink:
Before adding power mods, get a baseline dyno of your stock ride after the car has been broken in properly. then add the mods, and then dyno away :shock: :D
randode
01-22-2004, 06:26 PM
i had no fitment issues when installing the Injen intake on my wifes xB. Nothing sharp, and everything had plenty of room.
Workbox
01-22-2004, 08:26 PM
Thanks guy's! All your info is great and I feel pleased to be part of the Scion family. It gives me comfort that many issues can be pm'd and the feedback very helpfull.
DibujoB
01-22-2004, 08:43 PM
I'd have the SPFR intake. The intake is outstanding, and there's an SPFR exhaust coming soon which is a true cat-back, and will add horsepower without sounding obnoxious!
welcome to the Scion family!
scionaraxb
01-22-2004, 08:48 PM
Workbox-
I'm an older guy too, and like the car for the way it looks as well as the things you mentioned.
I too, wanted to make a bit more power then stock and not sound like a kid driving around town. I went with the AEM after I bought my car and then added the TRD muffler after that. I can tell you that the AEM seems to make a difference, although not huge. The TRD on the other hand was crap, it killed the torque as 1NZEFE said, and it was louder inside the car then it was outside. It may have made a tiny bit more power in the upper RPM's but I doubt it. My very young kids didn't want to ride in Daddy's new car after I put it on...they complained about the noise!! I took it off after 5 days and eventually sold it for a huge loss. After putting the stock muffler back on and putting on a tip (I liked the look of the TRD) I noticed a BIG difference in driveability...it was MUCH better with the stock muffler!
PM me if you have any further questions..like how to get it to ride better!
George
01-22-2004, 09:10 PM
Since you use the word "conservative", I'd suggest that you try the car in its stock configuration before you go for modifications. It's surprisingly quick.
George
kcarroll
01-24-2004, 04:19 PM
I just wanted to let you all know that. They are here! I'm a sales rep for Don McGill Katy and I got an xa and B this morning. We cannot retail them until Feb 3. But it might be a good idea if you for color purposesor other modifications. Questions, you can call
sithscripter
01-24-2004, 04:45 PM
Worst follow-up ever ^^^^^^^^^
(in Comic Book Guy voice)
kcarroll
01-25-2004, 01:44 AM
I just want to say i found you and thank you for the info on this site. I am hooked and I love here. of course all of us here are hooked on something, SCION. See you FeB 03. We love you MaN!
Kim (scion-chic)
Docsnuff
01-25-2004, 02:10 AM
Kim (scion-chic)
Hmm, Maybe Kim might volunteer for the Women of ScionLife calendar?
Doc
Al-Truistic
01-25-2004, 12:55 PM
Workbox-
...After putting the stock muffler back on and putting on a tip (I liked the look of the TRD) I noticed a BIG difference in driveability...it was MUCH better with the stock muffler!
Hey! What does your exhaust tip look like? I wsa thinking about the TRD mufler, butam concerned about the noise and since power gains from the exhaust is minimal at best, I thought maybe I could get a neat tip at least. Did you find a good place for them and any recommendations or tip tips to share?
Cool beans!
