trd spring users
Originally Posted by dimebaggin
there is a shop here that does an alignment right after they install the springs.
Originally Posted by GammaTNT
they was a shop that told me i can get away without alignment.
Just a little FYI. I've had an alignment issue with my car since day 1 (it pulls to the left). So I've had my car on the rack when it only had 200 miles on it, then installed TRDs and it's been on the rack twice more since I installed the springs. The specs are EXACTLY the same with the TRDs as they were without. You really do not need an alignment with TRD springs.
Oh, by the way, nice attitude! I bet you've gotten real far in life with that... lol!
Originally Posted by tCs_are_life717
^^ Good call out
You have the burden of proof to show me that I am wrong, however since you can not produce, I will still believe all that I was taught to believe that when you change the geometry of the suspension (springs that are lower) that an alignment is needed.
I understand how suspension geometry works. And I've also been taught my whole life that if you lower a car you must get an alignment. I was a tech for 7 yrs, went to UTI, and went to a vocational HS for automotive. So I'm not disputing the fact. But I've seen the printouts from 3 different alignments and 2 different Toyota Dealerships. The specs were that same as stock. You don't have to take my word for it, I could careless. I was just putting out some info that I thought ppl could use. Don't let me tell you not to get an alignment. By all means get 1, you should. But with TRD springs it isn't necessary......
^^ Good call out
