INTAKE MANIFOLD
Old Mar 3, 2009 | 03:24 PM
DUANYS's Avatar
Default INTAKE MANIFOLD
Is anyone here using the descendant intake manifold, or their cable throtle body. if so what mods have you guys done for it to work right?
Old Mar 3, 2009 | 03:30 PM
wlfpck's Avatar
learn to search....
If you had searched instead of being lazy... you would have found the weapon R intake manifold...
Old Mar 3, 2009 | 03:58 PM
DUANYS's Avatar
i am on boost i dont need long runner, ive searched for that one already. i just wanted to know other peoples posetive opinions.
Old Mar 3, 2009 | 04:05 PM
ippskidder's Avatar
1UP Crew
Originally Posted by wlfpck
learn to search....
Wow.
That was an ASinine thing to say.
If you would have read past the title, you would have seen he wanted clarification on an intake manifold. Not where to find someone who makes an intake manifold.
That just makes you look lazy, lmao.
Anyways.
OP let me see if I can remember the screen name of the guy from puerto rico who did something like that I believe.
Old Mar 3, 2009 | 04:06 PM
ack154's Avatar
learn to search....
And as the rules state, don't just tell someone to search... help them search. Give some keywords or threads that YOU found while searching.
Basically, don't be a dick.
Old Mar 3, 2009 | 04:11 PM
ippskidder's Avatar
1UP Crew
Default Re: INTAKE MANIFOLD
Send a message to Mecanica_Pito
Maybe he can lead you in the right direction. I know he did a TB swap on a tc, with something a lot bigger. He's also built some quick TCs.
Edit: Just saw this too, lol.
https://www.scionlife.com/forums/viewtopic.php?t=252133
Old Mar 3, 2009 | 04:24 PM
DUANYS's Avatar
Yes the blitz kit is quite ok but only for better throtle response it will not make you achive 100% open throtle. normaly our throtles only open up to 81% which is not bad, but as for me i have the s/c and the tune closes your throtle up to 40%+/- when stepped on around 4k thats why when you install a boost gauge your boost will drop. the only way to get passed this is to either install a cable throtle or get a new ecu and tune it myself. thanks for the help
Old Mar 3, 2009 | 04:29 PM
ippskidder's Avatar
1UP Crew
I guess i'm trying to figure out what you said ^^
So in reality, the TB only opens up about 81% when at WOT??????
If so, the only way to get passed this is with a Cable'd TB????
or an ECU swap (standalone/piggyback?)???
I have a hydra btw.
Please explain, lol.
My curiousity has gotten the best of me.
Old Mar 3, 2009 | 04:41 PM
DUANYS's Avatar
i figured this out when i was tuning the car, i have an fic btw. in 1st and 2cnd gear you will see full boost in your gauge but when in 3rd and so on your boost will drop at 4k rpm this is a safety that trd did to protect the motor, its part of the trd tune. the s/c can actually produce alot more power if it wasnt for this feture. i dont know about the earlier years but mine is an 08 and it does this. if you want to see how your car is running, hook up and actron auto scanner and you can see all the paramaters of the motor.
Old Mar 3, 2009 | 05:35 PM
yamaha16bw's Avatar
I'll be installing my Descendant IM very soon. Keep an eye out for the thread starting soon with dyno numbers. Still prolly a few weeks away. Stock throttle body though.
Old Mar 3, 2009 | 06:40 PM
Ace83's Avatar
Ronin Scion
it will be interesting to see how the 3D fuel map would look after the tune
Old Mar 3, 2009 | 07:04 PM
Cwatz5219's Avatar
I have a hydra btw.
Yeah my scangaugeII shows that throttle on our cars maxes out at 80%. I have an 07. I Checked my buddies 06 and his shows the same.
Old Mar 3, 2009 | 07:06 PM
Ace83's Avatar
Ronin Scion
hydra log shows 102% at WOT lol
Old Mar 3, 2009 | 07:16 PM
DUANYS's Avatar
IS YOUR FRIENDS SUPERCHARGED? OR YOURS? AND DOES YOUR TPS DROP AT LIKE 4K RPM?
Old Mar 3, 2009 | 07:19 PM
brett561tc's Avatar
my friend aj (aka dyltone) is using a custom intake manifold with a cable throttle body. he has a dta s60 pro standalone for engine management, and had to have some custom work done to run a throttle cable frome the petal to the TB.
he's driving it daily and has no problems with the cable throttle setup. here's a vid from the dyno.
Old Mar 3, 2009 | 07:23 PM
DUANYS's Avatar
THAT WAS A GOOD PULL. DID EVERYTHING HAD TO BE CUSTOM
Old Mar 3, 2009 | 07:28 PM
Ace83's Avatar
Ronin Scion
havent heard of that setup in awhile.. its badass
Old Mar 3, 2009 | 07:32 PM
ack154's Avatar
Please... the CAPS... turn them off.
Old Mar 3, 2009 | 07:34 PM
DUANYS's Avatar
lol
Old Mar 3, 2009 | 07:36 PM
ack154's Avatar
lol
You laugh, but it is one of the forum rules.
