Best injector cleaner?
Old Mar 3, 2009 | 07:56 PM
irelandsboy's Avatar
Default Best injector cleaner?
What is the best fuel injector cleaner ?
Old Mar 3, 2009 | 08:33 PM
bB2NER's Avatar
Music City Scions
The best I've used is Seafoam. Not only does it clean the injectors but it also cleans the valves, pistons and combustion chambers.
Old Mar 3, 2009 | 08:57 PM
vettereddie's Avatar
x2
Old Mar 3, 2009 | 09:15 PM
xBHAWK's Avatar
Default ....QUESTIONS....
How would I use that SeaFoam to clean my injectors?
Is it a spray? Add it to the gas?
Would this work for a throtle body cleaning?
Old Mar 3, 2009 | 09:24 PM
Easiest way is to add it to the gas tank, 1 pint for a full tank.
If' you're loking to clean the throttle body, you'd need to slowly pour 1/3 pint through the PCV valve hose feeding the throttle body. I don't really recommend this unless you're engine is high mileage. Instructions are on the website here:
http://www.seafoamsales.com/motorTuneUpTechGas.htm
You can also send injectors out to have them cleaned in a machine if you're that worried.
Me, I'm a bit of a neat freak, so when I do my engine I make sure it comes out spotless INSIDE and out:
Old Mar 4, 2009 | 02:12 AM
Metro273's Avatar
Luckily, I have access to a machine that cleans the injectors at work. The product we use is by BG Products, it's called 44K.
Old Mar 4, 2009 | 02:28 AM
frogbox's Avatar
The best method is to take it into a shop and have it done by a pro , 44K was mentioned.
If your looking for a drop in tank type go with Lucas Tune-Up in a bottle. It also has a fuel pump lube in it.
My second choice would be Chevron Techron.
RP also makes one.
Most others are just a mix of kerosine and alcohol.
Old Mar 4, 2009 | 03:33 AM
Sciond's Avatar
Seafoam ftw
Old Mar 4, 2009 | 04:00 AM
bB2NER's Avatar
Music City Scions
They make special throttlebody spray cleaner like carb cleaner but special to not damage the throttlebody.
Seafoam works so good it sometimes cleans motorcycle carburetors so they don't need rebuilding. It cleans as you drive and does wonders. Best thing is it's under 8 bucks a can.
Old Mar 4, 2009 | 04:23 AM
Sciond's Avatar
$9.99 now locally!
Old Mar 5, 2009 | 08:06 AM
bB2NER's Avatar
Music City Scions
$6.99 locally at wallyworld minus my 10% employee discount.
Old Mar 5, 2009 | 12:29 PM
Wallyworld gets employee discounts? I might want to be a weekend greeter then as much as I spend there.
Old Mar 5, 2009 | 04:58 PM
KY05XB's Avatar
How many miles is it recommneded to use a in the tank cleaner?
Old Mar 5, 2009 | 05:12 PM
bB2NER's Avatar
Music City Scions
You get 10% off everything but food and prescriptions. It comes in handy especially nowadays.
Old Mar 5, 2009 | 05:14 PM
bB2NER's Avatar
Music City Scions
I treat one tank every oil change. The mix is one ounce per gallon of fuel and keeps everything clean and running great.
Old Mar 5, 2009 | 06:16 PM
Sciond's Avatar
It now in the tank and this weekend in the intake.....this is only stuff I have ever seen that works
Old Mar 6, 2009 | 01:37 AM
jetblast's Avatar
Seafoam products work great. I've also had great luck with 3M products. Both the intank, and the injector cleaing stand show great improvements.
Old Mar 6, 2009 | 06:07 AM
L33TFooMaster's Avatar
My box just rolled over 80k and I think it still runs great. But I've been thinking about something like this lately cuz I've been driving it pretty hard now... the milage is starting to drop slowly.
However, I try to remind myself that it's probably just because it's been hard driving. If I re-adjust my driving habits it might fix itself. I've never used this kind of product on a fuel injected vehicle before, I'm not convinced it would work.
-- tl;dr. I'm a forever skeptic. I don't believe it makes a noticeable difference. Is it really worth it? Will i see a difference?
Old Mar 6, 2009 | 08:05 AM
bB2NER's Avatar
Music City Scions
With 80K on your box, a tank full treated with Seafoam will def. help. 1 can treats 16 gallons. Just be sure to run the tank down below 1/4 before filling up again to get the full benefit. It truely does wonders to regain lost performance and mpgs.
Old Mar 7, 2009 | 12:17 AM
frogbox's Avatar
Used Seafoam in an older ( 1990) mini van it helped, but Seafoam is strong and can loosen up and clean out too much crud making a repair needed even more. And it completetley ruined the intank filter on the fuel pump , dropping that tank was a real PITA.
just be warned.
