anyone install a rocker switch?
Old Mar 3, 2009 | 07:57 PM
jaytrey's Avatar
Default anyone install a rocker switch?
If you installed a rocker switch, please put up your pics.
I am thinking about the ones from oznium and put them where the stability button is.
I know they do not fit snug with the dash, please post pics or a DIY on how to successfully do this.
What i have in mind are 4 flex leds: 2 in the front footwells and 2 behind the rear seats. and possibly one in the trunk.
anyone have any good tips on how to pop that piece out? reach under the dash or take the entire panel off?
Im thinking about the led lit rocker switch.
Anything i should be careful about?
I think everything i need is on the oznium website.
4 flex leds
1 16 gauge atc fuse holder
1 5amp fuse
1 led rocker switch
4 feet of extra gauge wire just incase.
please advise on anything i might be missing or any difficulty cutting the empty space out and fitting the new rocker in
thanks.
Old Mar 4, 2009 | 02:25 AM
Hustler74's Avatar
Sorry for the size.. The blank switches should pop out, or just pull that panel off and press them out from the back. One switch is for the lights in the car, the other is for the LED's in the Grill/Headlights
Old Mar 4, 2009 | 02:35 AM
jaytrey's Avatar
damn that is sweet. where did you get ur parts from?
the blank ones pop out meaning ...by pulling them out?
did you just drill into the blank enough to fit the rocker switch?
also, those led switches seem bright as he ll...are they distracting in your opinion?
Old Mar 4, 2009 | 03:24 AM
Hustler74's Avatar
The LED strip and Cathode I got from Oznium, switches from AutoZone..If you use a vrey small flathead screwdriver the blanks will pop out, or pull that panel off..It snaps off/on. As far as the brightness, its not that bad. They arent on all the time.
Old Mar 4, 2009 | 03:28 AM
jaytrey's Avatar
so u popped it off and drilled into the piece that you popped off correct?
is there a difference between the switches from oznium?
i meant the brightness on the switch itself, not your footwells. those leds seem really bright on the switches
Old Mar 4, 2009 | 03:59 AM
Hustler74's Avatar
Yes, popped off and drilled
I think Oznium have the same switches--AutoZone has diferent colors I think
And I was talking bout the switches
jayz0302
Jan 18, 2024 09:53 AM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
randode
44
Jun 29, 2004 04:19 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
