Can Hydra pass OBDII inspection?
Old Mar 4, 2009 | 04:27 AM
tC_2NeR's Avatar
Default Can Hydra pass OBDII inspection?
I think the answer is NO.
but i wanna make sure
Old Mar 4, 2009 | 04:40 AM
TheQuietThings's Avatar
zzzz
Old Mar 4, 2009 | 04:42 AM
OC3RULZ's Avatar
OhioScions
v2.5 no, v2.6 I do believe can bc my CEL has finally stopped blinking
Old Mar 4, 2009 | 04:44 AM
tC_2NeR's Avatar
hmmm....
but my theory is that the hydra wouldnt be compliant with the OBDII port tho right?
like u cant scan for codes n such since all the factory sensors arent being used by the stock ecu anymore?
Old Mar 4, 2009 | 01:13 PM
CarbonXe's Avatar
I'm going to go ahead and just say no.
Old Mar 4, 2009 | 01:21 PM
Ace83's Avatar
Ronin Scion
its a no.. even for the 2.6 i believe.. even though there is no light on the dash if you plug you OBD scanner it will show multiple codes for the factory sensors not used
Old Mar 4, 2009 | 03:07 PM
OC3RULZ's Avatar
OhioScions
I'll tell you what, I'll go to my buddies to see if my car is still throwing codes but not showing them. How about that?
Old Mar 4, 2009 | 04:23 PM
Ace83's Avatar
Ronin Scion
yup you can go ahead and do that to verify... but with hydra not using the primary O2 and maf sensor im 100% sure it wont pass, OBD scanner will always look for those data
Old Mar 4, 2009 | 04:28 PM
rhythmnsmoke's Avatar
Music City Scions
I have asked this before in the past. And after much digging, have rested with the answer as being NO with the same reasons as mentioned above. However, some users have come out and said that the Hydra can use the factory sensors, so "Theoretically" might be able to. But no one is/has tried it. I would like for someone to take the time to actually set it up using all factory gear to see if it would pass.
This is the reason why I went with the next best thing...Emanage Ultimate.
Old Mar 4, 2009 | 04:38 PM
Ace83's Avatar
Ronin Scion
I used to use all factory sensor before, like everything plugged like the maf and primary O2 and still throw few codes.. regardless if its plug or unplug its still show codes some different kind.. hydra sorta blocks input from primary O2 and MAF sensors no matter what.
Old Mar 4, 2009 | 04:57 PM
ScykotikPwdr's Avatar
Well I'm gonna have to say Yes/No because I work at the emissions station in PHX and if we plug into your OBD 2 port and get no response from the vehicle 1 of 2 things will happen both start with manager coming over , to verify vehicle has not responded to our systems, they will retry a couple times, then they will do a manual check to make sure no warning lights come on when the vehicle is started Note if your CEL is on, don't even bother going in) Then this is where the white shirt's discretion comes into play as they can either pass you and put you on your merry racer way or sentence you to the state retest center of DOOM! aka (A.D.E.Q.)
Old Mar 4, 2009 | 05:21 PM
toyota_scion_tc's Avatar
X2
All standalones or piggybacks will have OBDII codes or show that the sensors are incomplete test need to drive. (I forget the exact words when you plug in a OBDII scanner).
Old Mar 4, 2009 | 05:23 PM
The Hydra does use OEM sensors but it is still in control of the engine so it will always have hidden codes until you connect a OBDII scanner to it.
Old Mar 4, 2009 | 05:24 PM
equinox2355's Avatar
One problem that I can see is that the hydra EMS would not pass along the VIN like the factory ECU would.
That's my understanding at least.
Old Mar 4, 2009 | 05:41 PM
Nope, Hydra runs parellel with OEM ecu so it will still show.
Old Mar 4, 2009 | 06:07 PM
tC_2NeR's Avatar
bah, im still thinking about getting it.
When nys inspection rolls around can i just
Return to stock injectors and ecu and drive in granny mode?
U think a code will pop up?
Old Mar 4, 2009 | 06:09 PM
CarbonXe's Avatar
Something is bound to show up. Should have bought your car in Jersey lol.
Old Mar 4, 2009 | 06:15 PM
tC_2NeR's Avatar
Im really starting to freak out now...
Does ur fic throw codes Jon?
Hurry up Dezodddddd i need the new ems
Old Mar 4, 2009 | 06:29 PM
CarbonXe's Avatar
I have a code for no O2 sensor, but nothing else. Also, just because you don't have have a CEL, doesn't mean an OBD2 scanner will pull something. You can clear codes and they'll instantly come back as pending codes.
Old Mar 4, 2009 | 06:48 PM
tC_2NeR's Avatar
no 02 sensor wats that code number?
I have a too rich and maf out of range code.
Is the bov causing it to throw the rich code, or
Is it the 02 skew map?
