No Dash Turn Signal Indicators...
Old Mar 4, 2009 | 03:34 PM
RedneckwithanxB's Avatar
Default No Dash Turn Signal Indicators...
So tuesday, I unwrapped the xB after letting her sit during the winter... Ploped her new battery in her, cycled the key a few times to make sure the fuel system was primed, and she started right up as if I last drove her yesterday. I let her just sit in the driveway and idle for a good 20 minutes while I put all the plastics back on, and once she warmed up she purred like a kitten... drove her around the block a couple times and noticed that my front turn signals are no longer working, and the dash indicator was flashing fast. took her on a few errands, grocery store, bank, picked up a hooker. nothing to strenuious and only took surface streets to get all the fluids going again... on my drive the dash indicators just stopped working for the turn signals. Stopped and checked all the underhood fuses and they are all peachy... bought replacment bulbs and they didnt change it... and all my wiring is solid... even pulled the cluster and checked the LEDs... and they are good
Im confuzzled
Old Mar 4, 2009 | 06:41 PM
bbszero's Avatar
Flasher???
Old Mar 4, 2009 | 07:17 PM
no lights on the cluster at all as far as turning indicators go, be it with the turn signal or the 4 ways
Old Mar 4, 2009 | 07:21 PM
SW_08's Avatar
check your fuses...
i know you did already but one might be bad although it might look like theres nothing wrong with it
Old Mar 4, 2009 | 07:23 PM
Originally Posted by SW_08
check your fuses...
already did
Old Mar 4, 2009 | 07:26 PM
SW_08's Avatar
when you turn on your turning signal does it click?
you might wanna check the directional relay
Old Mar 4, 2009 | 07:30 PM
Is there a relay on the turn signals... I honestly didnt listen for clicks, just used to go off of the white turn LEDs... Ill try that on my way home...
Old Mar 4, 2009 | 07:32 PM
SW_08's Avatar
there should be...
if you hear a click then your relay should be good....if you dont then that might be your problem
Old Mar 5, 2009 | 03:21 AM
Relays are clicking just fine
Old Mar 5, 2009 | 12:06 PM
SW_08's Avatar
i dont know dude...thats the only thing i can think of....maybe its the curcit board or something....im running out of possibilites
Old Mar 5, 2009 | 05:47 PM
DJ_SpaRky's Avatar
Maybe it was the Hooker, sabotaging them ROFL
Anyways, the lights outside work, the fuses are fine, the relay is clicking and the LEDs in the cluster are fine, right? What about the Hazards?? and I DON"T mean Bo & Luke.
Old Mar 5, 2009 | 06:10 PM
SW_08's Avatar
^ hahahaha
good point about the hooker
Old Mar 5, 2009 | 07:02 PM
Played around a little bit with a multimeter last night
Neither of the light work as far as turn signals go, but light for the parking lights, front or rear, all bulbs have been replaced... Im getting power to the colsole, but the lights on the console arent working, but the relays are clicking... and Im getting power to them, but not from them...
Old Mar 5, 2009 | 07:30 PM
DJ_SpaRky's Avatar
So the outside lights don't work either? or just the cluster?? Did you check/change the flasher? Also, the relay may click and still be bad, if the secondary contacts aren't completing the circuit
Hey, get on IM.
Old Mar 5, 2009 | 09:46 PM
ajayaitch's Avatar
check your fuses...
already did
underhood as in "under the hood in the engine compartment", or as is in "in the engine compartment and by my left knee"?
Old Mar 6, 2009 | 02:20 AM
all the fusues as in under hood, under dash, and attached to the positive terminal
Old Mar 6, 2009 | 02:50 AM
DJ_SpaRky's Avatar
Bubbles knows where the fuses are, he's blown most of them at one point.
I'm thinking a Resistor in the cluster (try a different cluster) or the flasher module (replace it)
Old Mar 6, 2009 | 03:44 AM
Im going to kill Amanda for giving me that nickname... But yes... there really isnt a fuse that I havnt blown in this car... the one that really hates me is the one for the ECU, I think the ground on my Emanage is weird...
Im thinking that it might be the relays... I am gonna try to find me a toyo in the junkyard this weekend when I go hunting for Saturn body panels, so we will have to see what I can find... Cuz there is no power coming out of them, but there is power going in and they are clicking away...
Old Mar 7, 2009 | 10:32 PM
DJ_SpaRky's Avatar
Well, let us know if you find some, if not, you might have to justify me going to Skycraft ans getting them there.
Old Mar 8, 2009 | 04:59 PM
cold rain mixed with snow all weekend, so I am gonna hit the yard monday after work hopefully...
