Problems with hella supertone
hey guys, after installing my hella supertones on my car, the next day it stopped working. At first it was working but then the next day some car cut me off cold and I honked and held it for 3 secs and suddenly it stopped working. I'm not sure what went wrong, if it was the harness itself or the horn or the way I grounded it. I did the same exact install here from clubsciontc.com(the link is below) and didn't use the relay that came with the hella supertones for some apparent reason. Is it recommended to install and use the relay or what? I did the same exact steps that were shown from clubsciontc.com. thanks and help is appreciated!
http://clubsciontc.com/forums/diy-in...-of-pics-7975/
Check this post out. includes info on the relay.
https://www.scionlife.com/forums/vie...ella+supertone
Doesnt look hard to setup w/relay, and you probably should.
I've been having a similar problem, and I was actually just about to post about it.
My horns are wired with the relay though. They seem to work whenever they want and I haven't figured out what the variable is so far. All my fuses are fine and I'm completely clueless.
RY_TC07
Jul 18, 2017 05:18 PM
