Import Tuner dyno tests common xB2 bolt-ons
Sorry if this is old news but I haven't seen it posted here.
http://www.importtuner.com/powerpage...rs5/index.html
Originally Posted by FromTheOld
Good stuff to know. Automatics rob power like crazy
Automatic xB2 Stock - ~125-130 WHP
Manual xB2 Stock - ~150 WHP
Automatic transmissions always rob power like crazy in every car, but dynos aren't always the full story in performance
however, automated manual transmissions that actually operate a clutch, like vw/audi with their dsg gear boxes, and porsche's pdk, do make the same power, and actually shifter faster than traditional manual transmissions, so they transmit the same power that the manual does.
Originally Posted by coryjames
i will stick with my stick oh yeah i enjoy driving so yeah autos have there place for getting grocery's and teaching girls to drive
yes a auto is more consistent and better for drag racing but the fun factor is gone dog boxes and no lift shifting are also in play now with 2 step boxes and stuff like that either way you look at it the best way to harness power is a mechanical linkage not through a slush box the holding caps of a auto are also less they are more finiky and take some time to set up manuals are simple not relying on fluid pressure not to mention the heat factor
Also here's another question, are you willing to put up with a clutch that's uncomfortable to drive just so you can handle the power in a manual car? Yes, there are twin disc clutches, etc. but the fact of the matter is that if you're not spending over 1000 grand on a damn clutch, you're going to be uncomfortable driving.
I'm not bashing manuals, and I'm not saying automatics are the best, but they both have their purposes and neither transmission choice should be dismissed so easily.
This is true, which is why I put "~" in front of those figures, but generally, automatics rob a lot more power than manual transmissions do.
Originally Posted by draxcaliber
traditional slushbox automatic transmissions (which the xb has) do rob alot of power form the engine, because it is much less efficient way to transmit power than a manual transmission. this is why acceleration times between the same cars with different transmissions are often much slower, that and slight gearing differences.
FromTheOld your statement about needing to spend a grand for comfortable clutch is false. Most clutches are about half that and are just fine. Heck I prefer a stiffer clutch when driving, it doesn't feel like it's going to break (like the stock one haha).
And you are right each have their own place, but the auto in the xb is plain weak. It would never be able to handle 300+ whp like the stock manual transmission unless you spend a lot of money on it. It'd be a different story had the auto xb came with a dsg transmission.
Yes, I know the automatic is plain weak. It has to be built up, which DOES cost a lot, but adding a transmission cooler to it allows it to handle SOME power before needing a build. After all, the #1 killer of automatic transmissions is heat.
Like I said, it's all preference. I notice that the younger crowd hates on automatic like crazy, and it's really unjustified.
you know my car probably makes the same whp as a auto just cause im at altitude less air density the rule of thumb it we loose about a second in the quarter mile here from sea level i run a stage 5 clutch master witch will hold 500ft pounds no problem the since we have a hydro clutch its not all that much heavier then stock
[quote="FromTheOld"]
Never said I hated it, I just don't like it when it's with a 4 cylinder engine. I do prefer an automatic in a v8 rwd vehicle though.
