View Full Version : Will these fit? Enkei EKM3 18x7.5 45 offset
cdeeznutz
03-14-2009, 08:25 PM
I'm looking into buying these EKM3's in 5x100 18x7.5 45 offset, will these fit? I'm lowered on H-techs right now. Just don't want to worry too much about rubbing. Also, will I need anything to adjust for camber so the tires won't wear unevenly? Thanks!
http://i31.photobucket.com/albums/c374/deezy3z/enkei_ekm3_gunmetal.jpg
Andrew1782
03-14-2009, 08:26 PM
I think those will be more tucked than the stocks. I think the stocks are a +42 if I recall ?
Someone correct me if I am wrong.
So they should fit but will not look flush at all.
ack154
03-14-2009, 09:03 PM
OEM is +45... so these will stick out about 1/4" more than OEM. Not flush, but out a little more. But they'll also be in a little more by the same amount.
You shouldn't have any rubbing issues that I know of.
O5_TRD_tC
03-14-2009, 09:30 PM
bad offset
ScionTEK
03-14-2009, 09:47 PM
with 7.5 width wheel you don't have to worry about rubbing until you get to +23 offsets with Htech/TRDish drop
DJ08tC
03-15-2009, 12:32 AM
Cavalierkid888 is running them on his SW. http://www.scionlife.com/forums/viewtopic.php?t=20258&start=2640
Toward the bottom of the page.
Andrew1782
03-15-2009, 12:54 AM
by the way I have similar wheels to those and there are a BEAR to keep clean and take forever!!!! just fyi
