Need help please!!
Old Mar 15, 2009 | 11:21 PM
Vlatkovic2's Avatar
Default Need help please!!
OK so today i was checking something under the hood and I accidently shorted the positive battery lead to my cold air intake, which instantly turned off my car. When I turned on my car the check engine light was on and so was the Track off light and the VSC. My car idles like crap and when I give it gas it struggles almost like if it isnt running on all cylinders. All the fuses check out good. So if someone can help me I would greatly appreciate it. Thanks.
Old Mar 15, 2009 | 11:38 PM
snowromance's Avatar
have you tried disconnecting the battery and letting it sit for a few minutes. then reconnect it and try again?
Old Mar 15, 2009 | 11:40 PM
Metro273's Avatar
You might have blown some fuses or an all important fusible link.
Old Mar 15, 2009 | 11:45 PM
Vlatkovic2's Avatar
yea I tried unplugging the battery but it didnt work. I've kinda run out of ideas here, and its driving me crazy!
Old Mar 16, 2009 | 12:21 AM
frogbox's Avatar
You more than likely now have a fried MAF/Air temp sensor
Old Mar 16, 2009 | 12:26 AM
Vlatkovic2's Avatar
would a bad air temp sensor cause all does lights on the panel to turnn on and cause my car to idle crappy?
Old Mar 16, 2009 | 12:39 AM
Vlatkovic2's Avatar
the best i can describe it when I press on the gas it kinda sounds like a wrx.
Old Mar 16, 2009 | 01:23 AM
frogbox's Avatar
Yep. The trio lights come on, goes into limp mode, idles like crud.
Old Mar 16, 2009 | 01:30 AM
Tomas's Avatar
Admin Emeritus
Your car is in limp-home mode (fail-safe mode).
If it's not a fuse then you probably did toast your MAF.
You really need to have someone look at what codes your box is throwing so you know where to start...
http://scionlife.org/Scion_Docs/2004...fe%20chart.pdf
http://scionlife.org/Scion_Docs/ODBII_codes.txt
http://scionlife.org/Scion_Docs/OBDI...al_extract.pdf
Old Mar 16, 2009 | 01:47 AM
Vlatkovic2's Avatar
well i just put my friends MAF on my car(luckily he has an Xb too) and it worked just fine. I went to kragen auto parts spent $109 and put it on. She now runs like a dream. Thanks for all the help!
Old Mar 16, 2009 | 02:06 AM
Metro273's Avatar
^^^Good job!
Next time, be careful man...
Old Mar 16, 2009 | 02:08 AM
Tomas's Avatar
Admin Emeritus
That worked out pretty well!
Glad your box is back in shape. :D
Old Mar 16, 2009 | 02:39 AM
Vlatkovic2's Avatar
yea it was my own fault it happened. I have to be more careful next time, this wasnt a cheap mistake....
Old Mar 16, 2009 | 02:48 AM
burstaneurysm's Avatar
Yea, careful with those MAFs.
Old Mar 16, 2009 | 03:08 AM
draxcaliber's Avatar
and this is why you always disconnect your battery when working under the hood...
Old Mar 16, 2009 | 03:32 AM
yes good advice. we live and we learn. just glad you were able to get it fixed without involving expensive troubleshooting costs.
