Sound deadning
yoooooooo
so i have a jl system and have some fatmatt already placed in a few certain spots. I want to stop that ___ trunk raddle that you hear with most cheap systems. So does anyone know the key spots to stop most or maybe all trunk rattle???
unfortunately, the tc has a problem with a rattle in the trunk/hatch even without a system. There are these fins that line both sides of the hatch. if you search there is a diy fix to this problem. I believe its quite a process though.
Originally Posted by Degooch
What im trying to get to stop rattle is the OUTSIDE of the car. So just wondering where key points for that would be
Crank it up, walk around the outside of the car and listen for noise. When you find something you don't like, press on the panel and see if you can stop the noise. Depending on the location, shape and how much pressure is required, you should be able to figure out whether or not damping material will do the trick for the area in question, or if other means of abatement are required.
Going for the "key points" that others post may or may not help your situation, but a little quick & easy work (as described above) on your end will certainly pay off.
