Squeaky and rattly trunk on '06 TC
Hello,
I just bought an '06 TC about a week ago. Since day 1, this car has has this incredible obnoxious squeak coming from the trunk. I removed the Styrofoam pieces from the trunk that hold the jack and whatnot in place. It still squeaks. I'm beginning to think it may be the seal around the trunk, perhaps?
Also, this is accompanied by a loud rattle when I go over larger bumps. I've checked my license plate cover and it's pretty secure. I think it's something else.
Any suggestions?
Any suggestions?
Originally Posted by jonathan110987
is it the trunk or hatch... the plastic around the actual hatch by the window tends to sqweek
Just found this... https://www.scionlife.com/forums/viewtopic.php?t=79677
Now if only I can find a solution to the squeak.
open your trunk... see that two panel what you can take off to change the bulbs... closer to the center on the wall there is two D shaped rings bolted... those D rings can be moved around a little bit.. those made lots of noise so i took them off. rattle noise.
check out my method. I did this in October 2007 and have yet to hear any hatch rattle...
https://www.scionlife.com/forums/vie...972&highlight=
Originally Posted by NYcarbonTC
let us know if you ended up fixing it and if it was that problem
Those two changes fixed the rattle. However, I still have the squeak. I think it's the seal around the hatch. Is there something I could rub on the seal so it squeaks less?
Originally Posted by Shukorb
Hello,
Any suggestions?
Any suggestions?
Call your dealer and see if your VIN is one that would be covered to have them fix it under the TSB..... or just try what Yanki01 did on his.
domincnTC
Aug 4, 2015 01:47 PM
