rcf22
04-02-2009, 03:17 PM
Strange issue I'm having with my audio system the last couple weeks... When I have my wheel cranked to the left, I hear an occasional crackling sound through my speakers. It seems to happen most often when I'm accelerating through a turn, but that might just be because I'm always cornering hard :p
At any rate, it only happens when the wheel is cranked left, and not right. Any reason this could be? Should I just try another grounding location? Right now my amp is grounded to the baby seat thingie bolt in the hatch. I'm sure someone will tell me it's the ground, but it seems strange to me that the noise is only heard when the wheel is turned one direction.
BZinn1
04-02-2009, 03:37 PM
loose speaker wire,did you solder the wires to the speaker terminals,if not it probably is shorting as you go in tothe corner.......and slow down.......we don't want to have another I just killed my tC thread.
rcf22
04-02-2009, 04:44 PM
The connections are solderless. I had heard that soldering speaker connections could bad idea since the solder can introduce noise to the system, dunno if there is any truth to that or not. I can go back and check the connections to the crossovers and then to the speakers though, that sounds like it could be a possibility. Thanks for the idea.
kiss_kiss_kill
04-02-2009, 06:34 PM
Y'know, it's weird. My supercharger interferes with my speakers.
BZinn1
04-02-2009, 07:22 PM
get louder speakers.........lol........sorry you know I had too.
kiss_kiss_kill
04-02-2009, 07:34 PM
Well, the issue no longer exists. The supercharger's sitting in a box in my garage, waiting for someone to come buy it, lol.
nodsetse
04-02-2009, 09:55 PM
A good solder connection won't induce noise into the system. The downside to soldering (besides more time & effort) is the potential to damage the speaker, due to overheating the voice coil. The possibility of it happening depends on the type of speaker, but you should always use a heatsink (like a set of hemostats in this case) clamped to the leads between the terminal and vc, to absorb a lot of the heat so it doesn't overheat the vc.
Nothing wrong with solderless connections when done right, but it sounds like one of yours may be marginal.
Mouse
04-02-2009, 10:36 PM
Well there could've been a few different reasons for that with the s/c on....but why did you decide to take it off? Didn't you spend a lot of time polishing the housing to a mirrored shine?
daxII
04-06-2009, 12:50 PM
Sounds like something is definitely loose somewhere. I would check all of your power and ground connections, especially if you're using distribution blocks. Check all the amp terminals as well as your RCAs on the head unit. Also, as long as you're not cold soldering your connections, soldering your speaker wire to mids and tweeters is pretty much the way to go. I've never had a problem going this route, either with sound degradation or intermittent output. Hope you're able to find the source of your problem.
