S/C cold air intake and remapping
Old Apr 4, 2009 | 08:03 PM
mitchkeller87's Avatar
Default S/C cold air intake and remapping
I have an HPS cold air intake and I just bought a supercharger for my Tc today. Someone told me there is no way this part will fit with my supercharger. Is this true? I will have to drive to get my ECU remapped. Is it ok to drive to to where I need to go? It might be a couple hour drive.
Old Apr 4, 2009 | 08:45 PM
jsg93085's Avatar
there is a way to get cold air intakes to work with the s/c but since the s/c is going to heat the air up as its compressed, its not worth it IMO.
the reason why everyone says that it won't work is because the s/c uses the factory airbox lid which has the maf flange. most, if not all, cold air intakes do not have the maf flange on the pipe that goes into the fender/wheel well area
you can run without the reflash, but stay out of boost and get it done by the dealer or get some type of fuel management (emanage, f/ic, etc.) if you dont want the reflash...
Old Apr 4, 2009 | 11:21 PM
if my local toyota dealer cant do it do you think another dealer might be able to?
Old Apr 4, 2009 | 11:26 PM
jsg93085's Avatar
any toyota dealer should be able to do it or order the reflash kit if they do not already have it.
Old Apr 5, 2009 | 05:10 AM
Do you know how hard it is to install the supercharger with a few friends and I. We are all very handy around cars. Also when I drive it to the dealer how hard is it not to make boost
Old Apr 5, 2009 | 03:32 PM
streettimetc's Avatar
^^dont go over 1/2 throttle and dont go over 3500rpm and you'll never see boost. i drive all week long and never see boost. to get good gas milage.
Old Apr 5, 2009 | 04:47 PM
what kind of gas mileage do u get with ur s/c?
Old Apr 5, 2009 | 07:53 PM
b52hDUNN's Avatar
my s/c 07 gets around 24.5mpg dropped from 27mpg. I got the reflash in the morning then installed the s/c after that. I installed the s/c myself. Easy to do but did take two whole days. You do need some special tools and at least two torque wrenches. Be prepared to make a few trips to sears for some tools. The most time consuming part is the oil pan.
Old Apr 5, 2009 | 08:11 PM
Thanks for the good idea of getting it remapped before I install it. We got a few torque wrenches around. What special tools are you talking about?
Old Apr 5, 2009 | 08:22 PM
b52hDUNN's Avatar
fuel quick disconnect, spark plug socket, metric allen wrenches/ sockets, serpentine belt tool.
JrTcs's Avatar
Running with a CAI, will make you run lean, a friend did it and had to get an AEM FIC to tune b/c he was running lean with the reflash and CAI on the S/C.
Old Apr 5, 2009 | 08:25 PM
I thought the reflash would be good enough for the tune.[/quote]
Old Apr 5, 2009 | 08:35 PM
b52hDUNN's Avatar
The dealer tune is only good for the stock s/c setup, not one with a aftermarket intake on it. Probably will run lean and may throw a cel.
Old Apr 5, 2009 | 08:36 PM
What plug and plays do people recommend?
Old Apr 5, 2009 | 10:17 PM
jsg93085's Avatar
aem f/ic or greddy ultimate (if you have the $$$ that is...)
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
miguelishu
Mar 9, 2015 02:38 AM
AxRxP
Jan 25, 2015 08:40 PM
IGotThatOrangeToaster
Jan 19, 2015 02:35 AM
