TURBO TOYOTAS Install( lots of pics)
hey there I bought SUPERXERO's parts from his V2.1 kit. what I got was
V2.1 el manifold
4 bolt down pipe and S pipe.
90 degree silicone coupler
charge pipe with hks adapter
two pipes that look like they probably go with the intercooler
intake pipe to turbo with aem dryflow filter
two t bolt clamps
two slim line radiator fans
intercooler
so than I bought
t3/t4 60A/R cold side 82 A/R hot side with 4 bolt exit Garrette turbo.
HKS SSQV in limited black'
intercooler brackets
so now i need to get couplers
oil lines
tbolt clamps
but I think I am missing a pipe. can anyone lead me in the direction of a post were it shows in details the same kit as mine ? I need to figure out what way to clock my turbo. I have not started but I know this is what will come up. I just started a new job so I will be finishing this kit a lot faster than i expected. I will start my own thread soon. just need to know how to clock the turbo and can someone explain to me how to mount the intercooler ? i have no instructions for this kit whats so ever so i dont have nothing to refer back to. thanks guys.
.82 A/R Turbine .60 A/R cold side and ebay gate ( will be running tial )
S pipe and some intercooler
Mani and Turbo
90- sure it goes to tb
dp
wat direction do i clock ?
i have two brakets with 4 bolts and two spacer washer type things and a couple of washers for the intercooler, how exactly does it mount ? thanks
ok so I have got more pics.
same pic i sent todd. thats what i got i forgot to put pics of those other pipes, my bad.
I like this one a lot. looks sexy in black,
Intercooler.
New pics on 4/11
clocked turbo
clocked turbo
Intercooler tabs
tabs I welded to bumper.
charge pipe 1
13b Rotary coming out for 13bt
RX7 87'
V2.1 el manifold
two t bolt clamps
intercooler
so than I bought
oil lines
tbolt clamps
Mani and Turbo
dp
Intercooler.
New pics on 4/11
clocked turbo
clocked turbo
Intercooler tabs
charge pipe 1
RX7 87'
I think i have the kit with the pipes that hang low. can anyone post pics of theirs ? or link me in the right direction. I hate the scionlife search system i never find what im looking for. thanks
post up some pics of what you have. you should also look into getting a vacuum block and some stainless steel clamps (home depot ones for pipes 1/4"-3/8" OD work perfect for every hose except the boost gauge hose)
what gauges do you have?
ill post pics soon. I am just test fitting everything right now. I am going to send it off to get every thing powdercoated at once. suspension components as well. so i just want to make sure i have it all now since its high on my priority list. new job = more money for my car= gets done faster. I have an ebay waste gate on their but just so i can fab a dump tube for a tial i am getting off a friend since he never used it.
thats what im doing right now. I am not driving my tc right now i have a dodge ram as my dd right now. I just want to get everything fitted good and done before i drive it. So i know everything is their after paint.
i have the turbo gaskets just need the down pipe one. I am planning on getting those last. I am going to swap over to longer studs, so i can have more support for the manifold.
Ok...
In the picts you have the oil drain pointed up...
so you will need to clock the chra (center section) all the way around. So that hole is facing down.
For the compressor housing you will rotate it so the outlet is facing towards the front of the car at a slight downwards facing angle.
In the pictures you sent me, you had all the ICP piping and intake. Where did they go?
As for the large 90 elbow coupler you posted, you will trim that down so it has 3" legs in either direction.
It looks like you starting install, but you are missing some parts still, so please do not forget about those.
Keep posting and between the "boys" and myself we will get you headed in the right direction.
Regrds-
Todd
Regrds-
Todd
haha what todd said, i didnt even notice the oil drain is pointing up but just the compressor elbow.. and oh you dont have a 90 degree elbow on your compressor outlet, you need one to mount to the hot side IC pipe
i would just go with a silicon 90 degree coupler
http://www.siliconeintakes.com/index...1132bc9efec4c7
or hit todd up...lol
ok, so your center section of the turbo needs to be clocked so that the square outlet hole is on the bottom
as for your piping, it looks like you have all of the pipes, but you will need another (smaller) 90 degree coupler for the hot side charge pipe to connect to the outlet on the compressor
other than the standard questions like "do you have the gaskets, silicone couplers, t-clamps, and bolts/nuts for everything" your kit appears to be complete
