elect.? necessary w/ turbo kit running 5lbs? install in bama
I just need to know if it is possible to run a turbo kit on the stock engine, stock injectors/ computer, on 5-6 lbs of boost? also is there anyone in alabama willing to help with the install?
By fail you mean doesn't make a whole lot of power then yes. But fail in that it will blow up your engine...no.
thats how zpi stage 0 was and no one had a problem with. either way crush i see what your saying and its like i was saying not to go cheap. if you just want a couple of whp then go with s/c but if you go turbo make sure you go the right way! not the cheap way! point blank!
ok i understand...the only reason i posed this question is because i just bought a used turbo toyotas kit from cessblood on here and i wanted to know would it be a major issue before i did an install...thanks guys
That's what a ZPI stage 0 is. Stock injectors, no management, no intercooler, and 6psi of boost.
But as mentioned above...Stage 0's used a smaller turbine. The larger turbo's I would not recommend this type of setup. t3/t4 turbo = No.
Originally Posted by trdtopcat01
yes it's a t3/t4...so i could do a partial throttle? manufacturer?
i was just talking to cess the other day, he misses his kit bad....lol
i kinda know how he feels....lol
then that means youv got the custom dumptube i made for him....it prolly looks like booty by now though.
but yeah with that turbo i strongly suggest engine managment (aem fic, greddy ultimate, ect) and 550cc injectors. if im not mistaken the wastgate spring is a 8.7psi spring....i could be wrong but i thought cess was running 8psi or more. if not im pretty sure you can run with stock injectors and the fic @ 5-6psi...i have done it on the same kit but not the exact same turbo i dont think.
i'm the one, hmm...something i need to know about? at any rate, still helpful advice...
