RPM wire/tachometer
Hey, i need to tap into my RPM/TACH wire for my windowswitch on my nitrous today...
i was wondering if the black wire under the dash (pin 9) will work. It says its a "data link" line tho.. \/
[Tachometer black ac data link connector under driver dash, pin 9]
Will this be sufficient? or should i splice it off the ECU, or 1st coil?
Any insight appreciated, or alternative methods aslong as they give instructions
Thanks
Thanks
Here is the ECU pinouts depending on the year of your tC:
05-06: http://www.dezod.com/files/ECU%20pinouts----.pdf
07 up: http://www.dezod.com/files/tC%2007%20Pins.pdf
Thanks. I found the tach 1... it seems to be E5-1.
But for the TPS.. everyone is telling me to tap into the brown wire, right on the actual TB. But on the diagram, it says the BROWN wire is for sensor malfunction, and reads over 5v. Even on the nitrous DIY it says brown wire, so i think thats still it?
NonStopTuning
Scion FR-S Drivetrain & Power
14
May 5, 2017 06:52 PM
javio24
Aug 13, 2015 05:27 PM
