Radiator Comparison Pics
Old Apr 11, 2009 | 01:07 AM
Keeshwah's Avatar
Default Radiator Comparison Pics
I had been investigating some radiator/fan options because my turbo is in the way of my driver side fan and I thought I would share. Rob Cardona from World Motorsports sent me a bunch of pics of the Mishimoto radiator and fan shroud that I thought I would share. I finally decided on the radiator with 1 push and 1 pull fan, which is what World Motorsports ran on their TA tC. If it's good enough for a race car it's good enough for me.
Installed:
Side by Side Comparison:
Shroud Depth:
Old Apr 11, 2009 | 01:42 AM
mattieg's Avatar
Did yours leak at all?
Old Apr 11, 2009 | 01:46 AM
Ace83's Avatar
Ronin Scion
looks good and fit looks great! i wish i could use shroud on mine but my clearance is just so tight.. but did i read it right, you have 1 push and 1 pull with both fans mounted behind the radiator? you should be running all pullers
Old Apr 11, 2009 | 12:43 PM
Keeshwah's Avatar
No, I'll be running the normal pull on the right side and push fan on the left side on the other side of the radiator. I won't be using the shroud because I need the extra inch of clearance for the turbo.
Old Apr 11, 2009 | 12:51 PM
Keeshwah's Avatar
I still have my stock radiator on the car, there's nothing wrong with it. I just want to increase the cooling capacity since I've added the turbo. And I don't want to put the fans on the stock radiator and later decide to upgrade the radiator and have to do the work twice.
Old Apr 11, 2009 | 02:22 PM
Ace83's Avatar
Ronin Scion
you got the mishimoto radiator already? i'd say do that first and use the stock fans.. i've noticed a push fan isnt as effective as a puller, and the fan shroud helps too
Old Apr 11, 2009 | 02:57 PM
Keeshwah's Avatar
I'm going to be but I have no room for a fan on the driver side, stock or after market.
Old Apr 11, 2009 | 03:09 PM
Ace83's Avatar
Ronin Scion
oh i see.. i thought you had your stock fans on your stock radiator.. which turbo kit do you have? you definitely would benefit with the mishimoto.. i suggest a 170 deg thermostat too
Old Apr 11, 2009 | 04:53 PM
Rob_DESCENDANT's Avatar
If you guys would like more pictures please feel free to PM' me and I'll post more detailed pictures up on this thread!
Thanks JEFF!
Old Apr 11, 2009 | 04:56 PM
Keeshwah's Avatar
I have the Treadstone kit with an upgraded turbo.
Old Apr 12, 2009 | 05:01 AM
Ace83's Avatar
Ronin Scion
i'll upload some pics on mine when i get a chance, i have 2 slim fans in front and one at the back (passenger side) w/ mishimoto radiatpr
Old May 9, 2009 | 12:04 AM
ippskidder's Avatar
1UP Crew
I have the same setup ^^
Old May 9, 2009 | 12:23 AM
yamaha16bw's Avatar
No shroud?
Which brand fans did you go with?
Old May 9, 2009 | 12:55 AM
Keeshwah's Avatar
No shroud?
I ended up going no shroud with 2 12" mishimoto fans.
greytc
Oct 26, 2015 07:53 PM
Spitfire23
Scion tC 1G ICE & Interior
Sep 8, 2015 03:31 AM
Frankie_Xenon
Sep 2, 2015 12:22 AM
