A/F ratio with 9.5psi s/c
Old Apr 12, 2009 | 07:22 AM
gompka's Avatar
Default A/F ratio with 9.5psi s/c
I finally put my uego in and i'm getting 13.3 a/f while in boost on a 9.5psi s/c. Anyway else want to chime in? Seems a little lean to me ?
Old Apr 12, 2009 | 11:26 AM
Mrsanchez925's Avatar
Has your car been tuned yet??
if it has then i dunno...
Old Apr 12, 2009 | 01:15 PM
ElevationTC's Avatar
OK.. Thats very bad..
Old Apr 12, 2009 | 02:03 PM
streettimetc's Avatar
thats not running lean. lean would be any thing higher then 14.7 and any thing lower is running on the rich side. stock trd setup at wot i bleave is 12.5 on the rich side.stoch is 14.7 and when tunned for max power you tune from 12.5-13.3
http://en.wikipedia.org/wiki/Air-fuel_ratio
http://www.fuelairspark.com/Products...p/targetaf.htm
Old Apr 12, 2009 | 02:16 PM
last time i check.. under boost 13.3 is lean.. I tune my car at 11.2 under boost
Old Apr 12, 2009 | 02:57 PM
Ace83's Avatar
Ronin Scion
13.3 is fine as long as the ignition tune is compensated and not tuned aggressive, afr tune is half the equation
Old Apr 12, 2009 | 03:04 PM
when i was s/ced with that pully and intake + headers I would see 12.1 afr
Old Apr 12, 2009 | 03:25 PM
Ace83's Avatar
Ronin Scion
is that on the s/c reflash? it maybe something to look at since i believe the ignition tune is like standard but the afr is lean..
Old Apr 12, 2009 | 04:55 PM
gompka's Avatar
yea its trd tune, its pulling a crap load of timing.
BlingSlade
Oct 19, 2016 12:39 AM
darkshadowofxdeath
Feb 11, 2015 05:38 PM
sfpower
23
Jun 7, 2006 06:24 PM
SupaWhiteTc
Mar 15, 2005 11:25 PM
