ksport coilover question
Old Apr 12, 2009 | 07:52 AM
N03L's Avatar
Default ksport coilover question
does anyone know the max drop on these coilovers? thinking about gettting these if i can get at least a 3inch drop. and how is the ride on these? are they better than the tein basic?(which i have right now)
Old Apr 12, 2009 | 05:09 PM
ihatemyxa's Avatar
ive heard 4 inch. do a search
Old Apr 13, 2009 | 04:39 PM
blown_xa's Avatar
it seems as though every coil-over kit except one is limited to rear drop amount. This is because the rear springs held in by the rear axle perches have to be a certain length or they will fall out over a bump. Unless the coil-over kit you purchase has adjustable droop/ rear shock length you are limited. STD coil-overs have adjustable droop.
I would not suggest buying Ksports anyhow, they are not made well.
Old Apr 13, 2009 | 08:15 PM
ToyoXrsPl's Avatar
what else would u buy ?
Old Apr 14, 2009 | 01:27 AM
Therealenthusiast's Avatar
Awww...lameee I just ordered a set..oh well..working with a budget is always a downer anyways.
Old Apr 14, 2009 | 08:07 PM
blown_xa's Avatar
http://www.ptuning.com/html/Item-Des...l&ModelDesc=xB
apparently we sell these and they have adjustable shock length which would enable you to lower the rear considerably.
Old Apr 15, 2009 | 07:05 PM
1epoXyBox's Avatar
Hmm, I have been using the ksports for almost two years with no problem. Why do you dislike them?
The front can definitely go 3 inches, probably more. The rear shocks can be adjusted, but I believe he is correct in that you can only go a limited amount in back. Mine are all the way down in back, which is about 2-3 inches I'm guessing. The riding characteristics are harsh, even on the soft setting. Overall, I am happy with them though.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
yardleyTC
Mar 6, 2015 10:03 PM
xBassist
9
Jan 21, 2004 07:34 PM
