SQ10 rattle
Old Apr 13, 2009 | 12:09 AM
x_Batman_x's Avatar
Default SQ10 rattle
Theres my eD SQ10 has started to kind of produce a rattling or flapping sound when it initially hits. There hasnt been a decrease in volume so i dont think its blown, I actually just think that the silver part on top is loose. Is there an easy way to fix this? I'd rather not send it to them because then I'll be a month without bass.
Old Apr 13, 2009 | 12:12 AM
O5_TRD_tC's Avatar
its hitting the mat
place something to space it
Old Apr 13, 2009 | 12:26 AM
x_Batman_x's Avatar
nope theres no mat over it
I made a false floor:
I actually went to an audio shop and they're the ones that suggested it is the silver logo part
Old Apr 13, 2009 | 01:48 AM
O5_TRD_tC's Avatar
o nice false floor. The silver piece does look cheaply made...
Old Apr 13, 2009 | 02:14 AM
BZinn1's Avatar
check the cone cover,they can come off,seen a couple on here that came loose,but can be epoxied back in place easily enough.
Old Apr 13, 2009 | 02:33 AM
x_Batman_x's Avatar
....whats this cone cover you speak of
Old Apr 13, 2009 | 03:23 AM
BZinn1's Avatar
that silver piece that says Elemental Designs,I have seen a few come loose and it makes a racket on the sub cone.
Old Apr 13, 2009 | 03:29 AM
x_Batman_x's Avatar
so... do you just recommend I rip it all the way off and try and glue it back on? or like run a thin bead of silicon around the edge and wipe away excess?
Old Apr 13, 2009 | 03:43 AM
Joyride's Avatar
Before you put silicon try to see which part is actually rattling idk if that makes sense. Sometimes you can see the rattling lol.
Old Apr 13, 2009 | 04:40 PM
joe4x2's Avatar
I had the same thing happen to me with my SQ10. I called them up and they had me super glue the silver cover back on which only helped for a day or two.
After that they sent me a new sub with a prepaid return label for the old one.
Old Apr 13, 2009 | 07:20 PM
nodsetse's Avatar
Originally Posted by x_Batman_x
...run a thin bead of silicon around the edge and wipe away excess?
No, please don't do that, no one should ever use silicone for speaker repair.
Most silicone puts off a massive amount of toxic fumes while it's curing, and those fumes are so strong they can actually cause the speaker's adhesive to come apart (they use glue in various places during manufacture), effectively destroying the speaker. This is why you need to wait several days before installing a speaker in an enclosure that's been sealed using silicone.
So what adhesive should a person use for speaker repair? They happen to make one;
http://www.parts-express.com/pe/show...number=340-076
It's strong, safe, and can be used anywhere, during cone replacement, dustcap replacement, surround repair, spider joining, etc.
Old Apr 14, 2009 | 12:29 AM
BZinn1's Avatar
yep a speaker glue or poly epoxy will work,check for visual of what is loose and make sure the sub is not bottoming out for some reason and that is what you are hearing.
yupinmytC
22
Jul 27, 2024 07:08 PM
steeze69
May 24, 2021 02:57 AM
mxwes
Aug 30, 2015 09:11 PM
BadCattitude
Aug 29, 2015 01:10 AM
SFXB
Jul 9, 2015 11:00 PM
