Vibration in dash of Scion xD
I posted back aroung the middle of March about the vibration and rattles in the dash of my xD. I contacted Scion at www.scion.com and got a phone call from a representative who had been on the phone with the Toyota dealer where my car was bought. Toyota called and made an appointment to get the car in. The service manager was able to make the dash vibrate by slowly applying pressure to the gas while the car was parked. They had the car for 7 days and thought the problem was solved but after two days home, the vibration started again. They didn't take the dash out, only the radio and tried to pad it that way. Now that it's vibrating again, they are going to call Toyota and see what the next step is and that will probably be to take the car back and they will have to remove the dash and pad the whole inside. It's frustrating because the dash vibrates at any given time and at no specific time so it's hard to just take the car when it's doing it's thing because 99% of the time, it stops before we get to the garage. Like I said in my earlier post, if all who are having this problem would please just report it to Scion, they will eventually recall the cars and compare notes with each of the garages and get to the bottom of the vibration. It can be very annoying at times and a new car should not rattle and vibrate.
When did you buy the car? I wonder if they tried fixing this later in the first model year. I have a RS1 that I bought in Oct I believe, and it doesn't rattle at all.
I recently replaced the radio and noticed there was foam in between the vents and the dash. I read some people had this done as the dealer, but I've never taken it in for rattles.
The only thing I get is a vibration on the passenger door from the radio. But I will fix that with sound deadening.
Originally Posted by ChelsDS
Is there a specific area that it rattles, or is it the whole entire dash soxmobile?
i just spoke with a scion representative on the scionchat:
GVan: If it's something that we are hearing from customers more and more it can go into review for a possible recall. As of now, Scion doesn't have any recalls on our products.
we should report this in..
Originally Posted by Dex117
my xD gets a raddleing sound to and it sounds like it comes from ontop or behind the radio deck
mine rattles. I don't care. it rattles primarily on the right side in the windshield. I heard it's an AC duct or somethin. I also stuffed towels down in the doors above the speakers to stop that rattle too.
As it stands right now, the dealer talked with a Toyota rep and they are ordering new pads for under the dash. I'll know more in a couple of weeks when the part comes in and they install it. My car doesn't care if it's hot or cold, it just vibrates in either temperature. It was at the dealer for 7 days the first time and there were times they got it to vibrate and times they couldn't. The next time, it was at the dealer for 4 days, thought they had it fixed but other rattles cropped up along with the previous ones. I will post when the problem is fixed and let you know what finally worked.
i'll tell yall what fixes this. not towels in behind the panels, cause the wife will at some point want to know where her spare towels are...foam tape. 1/2" wide x 1/2" thick foam tape from lowes. take off the door and dash panels and put foam tape on anything that looks like it might possibly touch anything else. i went thru 2 big rolls of it, but...no more rattles. also, under the dash where the center air duct comes from the windshield base to the dash vents its attached loosely by two tabs. use some F4 tape or elect. tape and cinch them down with it, that was the worst of the rattles. i have some pics, ill try and post when i get home. foam tape=quiet. (doesn't help with the wicked road noise thought)
It is amazing there is no TSB for this.
Originally Posted by imageex
Could you tell me real quick how you took the door panels off. That rattle is annoying in the doors
