DIY - Redesigned TRD Sway Install
Old Apr 14, 2009 | 06:37 PM
Invertalon's Avatar
Default DIY - Redesigned TRD Sway Install
Hey guys, received the bar today and decided to do a little DIY
1.) Open your box, and get excited!
2.) Here is my xB waiting to be risen for some modification
3.) Jack up your xB via the two jack points. Make sure to use wheel chokes up front and jack stands. You will need your jack later on, plus, its unsafe to support the vehicle via the jack at anytime.
4.) A look under "before".
5.) Use a 17mm 6-point socket and a breaker-bar to remove the shock bolt. May need to use a wrench on the nut-end depending.
6.) Nut off!
7.) I used the jack to push up on the spring/shock assembly so I can easily remove the bolt. Very helpful!
8.) Put in place the endlink. Need a 13mm wrench for this. They *ARE* left/right orientated, so make sure where you will attach the sway bar that it faces the rear of the car. I used a little Loctite 242 on the nut before I tightened it. (Torque to 32ft/lb, but it was impossible to get the torque wrench into that space. Guesstimate!)
9.) Used the jack to then lift up the assembly again so I can replace the shock bolt. It may be a good idea to clean the bolt threads with some alcohol and ensure there is no added friction along the way when you tighten the bolt (such as rust, or in my case, loctite from when I previously removed these bolts to install the springs). At this point, DO NOT TORQUE.
10.) Next, I used an old metal coat hanger to hold the bar up so I could mount it on the endlink. I did not torque the bolts at this point, just put them on to hold.
11.) Now do the other side. Same process as the left... Use breaker bar to loosen bolt, use jack to lift assembly, and remove nut and bolt.
12.) Install endlink the same way as before. Use jack to lift spring/shock assembly and replace bolt and nut. Do not torque this end either. Place other end of sway bar on the link, finger tighten. Should look like this:
13.) Random shot of install.
14.) Use the supplied silicon grease and lube up the bushing well. I lubed the bar as well, between the two welded points in which the bushing will go. No need to measure on the redesign. Just "spread" the bushing and push on, both sides.
15.) Assemble the brackets as instructed. Make sure orientation of the bolts are correct and use washers on both ends (at "head" of bolt and before you place the lock-nut). The drivers side is tricky to tighten the rear-horizontal bolt due to the gas tank(?), so you will need to use two 13mm wrenches for this, but all the others you can use one 13mm wrench and one ratchet. Its not bad, just a little time consuming. These are torqued to 24ft-lbs. Once one side is in place you can remove the bungee cord, coat hanger, or whatever else you help up the bar with.
16.) At this point, the sway is now installed but you are NOT done yet! Remember, we now need to torque everything so stuff doesn't fall off! For the endlinks, I applied a little bit of Loctite 242 and torqued both sides (obviously!) to 32ft-lbs.
17.) You are now ready to lower the car back to the ground. But you are still not done. You have to torque the shock bolts to 67ft-lbs, but after you lower it and push on the back end a few times to settle the suspension. I torqued to spec and then drove up my ramps so I had more room. You must have the weight of the car on the rear suspension before you torque those bolts. This is why you should not do it while it is on jack stands.
18.) Car was on my ramps (or you could leave it on the ground, but its a little tight for me), and I went through and torqued all the bolts to spec. Endlinks, shock bolts, and brackets. You are now finished.
19.) Remove from ramps and go drive around! All done!
Install was really straight forward and quite easy. I just take my time and make sure I do it properly. Took me about 1hr to complete.
Took it out for a spin and absolutely love how it feels. It is not as "rigid" as I was expecting in terms of road-roughness (good thing!), it actually feels near the same as it was before the install. The bushings may have something to do with this versus the 1st gen's "rigid" design. But when you take a fast corner you can feel the rear "sticking" opposed to wanting to lean out. The car still has some body sway don't get me wrong, but in general, it feels much more controlled and reduces the rear under-steer quite a bit. You can really accelerate out of turns much better with the sway installed. This is how the car should feel out of the factory! Feels so good!
If you have any questions feel free to ask! Hope this helps some of you in the future!
Old Apr 15, 2009 | 11:40 AM
kostonjohn's Avatar
Awesome write up bro I love these super detailed diy's it def. helps us out What kind of drop do you have & do you have the strut bar? I plan of getting both but just wanted to get your opinion on the combo if you have it.
Old Apr 15, 2009 | 03:11 PM
Invertalon's Avatar
I don't have the strut bar. As far as springs go, I have the Tanabe NF210's (1/1.7) (F/R).
Old Apr 15, 2009 | 10:51 PM
ShaffNasty's Avatar
I spy a Hockey puck... +1 for you sir... Unless you are a Blue Jackets fan, then it's -1,000,000...
Old Apr 16, 2009 | 12:12 AM
Invertalon's Avatar
Haha, actually I use three of them! One for my jack and two for my jack stands. All cut to "fit" and put in a slot for the frame rail to rest into. Works great! Was a pain to cut the pucks though...
Old Apr 17, 2009 | 07:05 AM
A-snell's Avatar
Great write up on the DIY!!! easy to follow, great pics..
Old Apr 17, 2009 | 06:20 PM
cincinfocal's Avatar
word...
so i have the old one...now with the use of those endlinks...versus attaching it straight to the shock base...would it make this one not as stiff? and less prone to breakage? also what do you believe caused the braking of the old one...
things i notice is that the placement of the bushings that go into the torsion beam are important enough to directly call out on the redesign...and could possibly (i dont know how) affect the life of the old sway bar....
but great write up! just tryin to figure out ways to make mine last and not brake :p
Old Apr 19, 2009 | 01:51 AM
XBERRYD's Avatar
Hey Invertalon, where did you buy it at?
Old Apr 20, 2009 | 02:29 PM
Invertalon's Avatar
Got it from TRD Sparks
Old Apr 20, 2009 | 06:47 PM
XBERRYD's Avatar
you have megan springs??
Old Apr 20, 2009 | 06:58 PM
Invertalon's Avatar
Tanabe NF210's
Old Apr 20, 2009 | 07:01 PM
XBERRYD's Avatar
ooo they looked orange, but where did you buy yours at?
Old Apr 20, 2009 | 08:48 PM
Invertalon's Avatar
I ordered them from ptuning, I used the scionlife code and got them quite cheap shipped. 189$? I don't remember exactly, but was the best price.
Old Apr 20, 2009 | 08:51 PM
XBERRYD's Avatar
yeah, on there its 198 shipped now. i'm gonna order them today
Old Apr 20, 2009 | 09:13 PM
Invertalon's Avatar
Good deal! They are excellent springs.
I will tell you what though, with these springs, the Falken Tires and the TRD Sway, my xB feels SO damn good on the road. On freeways its butter smooth, corners with ease, and just feels great all around. Its a power-house of a setup IMO for the xB. You think by lowering it and installed the sway bar and such that the ride would become jittery and harsh, but I think it has went the other way. It feels better now to drive then it ever has before, hands down. Just super happy with how my xB feels these days!
Old Apr 20, 2009 | 09:18 PM
XBERRYD's Avatar
i ordered the DF210's Actuallay!
Old Apr 20, 2009 | 10:01 PM
Invertalon's Avatar
I would of loved to go with the DF's, but driving around here in Ohio we don't have nice roads to drive around on with winter destroying any repairs they eventually do. NF's are a good trade-off. Enjoy your springs!
Old Apr 28, 2009 | 05:57 AM
NyoroBox's Avatar
great pics and write up! You wouldn't happen to know if the new TRD ones perform better than the older one do you?
Old May 13, 2009 | 12:51 PM
Geezer41's Avatar
Excellent write up!
Two additional notes: (1) You can use ramps if you don't want to deal with jacking up your xB. You just need to push the bottom of the shock back into place when you bolt everything together...which is no big deal.
(2) Make sure the bar is centered before you tighten the clamps. The measurements in the instructions are kind of ambiguous, so I used the holes in the bottom of the shock mounts as a reference to the end links.
Old Jan 14, 2011 | 09:44 AM
Red6's Avatar
anyone know how to get the pics back? i am looking for a diy on how do this for this weekend
CPL_Radar
Mar 5, 2015 05:42 AM
ScionDP
Mar 1, 2015 10:57 PM
JPuehl
Jan 10, 2015 01:01 AM
minter66
Dec 15, 2014 01:45 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
