AMP mounting
Old Apr 14, 2009 | 10:45 PM
kalfin2000's Avatar
Default AMP mounting
ok, i am replacing my door speakers and my backseat speakers. (Infinity Kappas) I already have 2 subs and 1 AMP. I think I am gonna get an MTX 4-channel. I don't know where to mount that AMP. On the seat is not an option. Maybe under the seat, but I wanna be able to access it. Anyone else have a similar setup? Where did you mount your amp? Pics if possible. I am also OCD about wiring, all the wires for my sub setup are hidden.
Thanks!
Old Apr 14, 2009 | 10:47 PM
GammaTNT's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=103100
check out this thread
i mount my amp on a circular board. I place it on the spare tire.
Old Apr 14, 2009 | 11:13 PM
Yanki01's Avatar
mine...
Old Apr 14, 2009 | 11:46 PM
kalfin2000's Avatar
I guess I could just mount it on the back of the subwoofer box with my other amp....
Old Apr 15, 2009 | 12:48 AM
wazzu_coug's Avatar
if you are wanting to mount it under the passenger seat, it's do-able, but i would not recommend it. you have to raise the seat up about an inch or so, so that the cables and seat do not hit the amp, when you slide the seat forward and back. also, it's nearly impossible to adjust settings; you pretty much have to remove the seat.
take a look at Yanki's picture above. thats where you should mount the amp. if you don't want to mount it there, you can also mount it in the foam cubby off to the right of it. a little trimming, and it should fit nice and snug. put one amp in the spair tire, and another in the cubby, to keep it super clean.
Old Apr 15, 2009 | 01:32 AM
CameronTX's Avatar
i put my amp in the spare as well.. i also have an amp to the right of the spare.. im using computer fans to circulate the air.
only thing i did different, is i mounted my amp a little deeper into the spare.. so the floor will sit at normal height
Old Apr 15, 2009 | 01:35 AM
Yanki01's Avatar
mine is at normal height aswell.
Old Apr 16, 2009 | 03:46 PM
rcf22's Avatar
If your amps are low profile you can do it like I did:
https://www.scionlife.com/forums/viewtopic.php?t=250741
Hydryman
Feb 23, 2016 03:35 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
DJrepresent
Aug 12, 2015 06:37 PM
