View Full Version : Squeeking Clutch Noise.... Plz Help
Chrno
01-13-2005, 02:23 AM
hello.... Today i was driving my XB and everytime you press the clutch down to start the car or to shift gears, It'll make a Squeeking noise... the clutch doesnt slip. it still grabs.... does anyknow know what is the cause of the sequeeking noise? is it becuase the cable line is bad? or air bubbles in the clutch lines? (ours is hydrolic clutch i believe) Please if anyknow knows please respond :cry: ... Thank You, I Appriciate it a lot!
-Mark
sciontc_mich
01-13-2005, 07:04 AM
might be the fork that moves the clutch.. my civic had this.. they had to grease it up from time to time.. also it might be the spring on the clutch pedal.. also civic had the same problem.. a little silicone spray up into that spring always quieted it down.. the fork in the clutch area? not sure about that, usually a little grease from the mechanic stopped that.. hope that helps..
if it's stil under warranty, the dealer should help ya out..
Daemon1313
01-14-2005, 07:34 PM
It could be you're throwout bearing. The basic symptom of a failing throwout bearing is a squealing or grating sound when the clutch pedal is pressed and held.
hotbox05
01-18-2005, 10:49 AM
i'd rather have a squeeking clutch then a slipping clutch like me lol
