new custom radio bezel trim piece
that is exactly what i did.....alot of work!...sanding the clear was a pain in the ___!!......painted the clear like 3 times to get the surface like glass........the plastic pieces have cruddy surfaces!
Did you use a cyanoacrolyte glue or more of an epoxy?
I've been seriously waiting for someone to do this. If I had a double din unit, I would've done this.
Definitely looks good!
Originally Posted by chaka_222
amazing outcome! what is "ppg" paint? Also, you mentioned that you had to sand the plastic. Did the paint have difficulty adhering to the surface?
you need to sand with 400 grit sandpaper to get some bite to the primer and then wetsand the primer to 600 grit and paint/clear the whole thing....
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
xa007xa
03-31-2015 09:24 PM
CONCRETETC
02-09-2015 08:05 PM
