Climate Control Light
Old Apr 17, 2009 | 06:52 PM
swensc's Avatar
Default Climate Control Light
I have a 2007 Scion tC and just recently have had a problem with the light on the climate control. The light works normally, but when I turn the headlights on, it goes out. So at night I can't see the time, temp and climate control info. The dealership told me the circuit board is going bad and needs to be replaced. They told me the circuit board is $680 plus installation. That is way to much just to fix a small light.
Does anybody know if there is a cheaper route to fix this? Does anybody sell these circuit boards cheaper?
Old Apr 17, 2009 | 07:09 PM
nodsetse's Avatar
Wrecking yard FTW! Get a used one from a parts recycler.
Old Apr 18, 2009 | 09:15 PM
Bulgdoom's Avatar
Default Re: Climate Control Light
Its a stock problem with the 07s, mine had the same pro. Its actually very easy to fix and u dont have to buy a new HVAC. One of the resistors isnt properly soldered so its messing up, if u just disassemble your unit and take out the circuit board, it will take u 1 min to fix.
Engifineer has the DIY instructions on www.yoursciontc.com under the lightning section of the forums. I cant post link since for some reason the site isnt opening atm.
To take the waterfall off, theres DIYs all over, even on youtube that gives u a nice step by step
Old Apr 18, 2009 | 09:17 PM
Bulgdoom's Avatar
Its very hard to find a tC in a junkyard since theres so few of em, new car. Most of em get rebuild and resold for that reason (mine is rebuilt).
I need to find a junkyard so i can steal a circuit board from the HVAC since my LCD screen cracked when i was installing my LEDs
Old Apr 19, 2009 | 06:18 AM
SquallLHeart's Avatar
not only it it a known problem, but they are supposed to replace it under warranty because of that
geez, brand new from the factory, it's more like $300. that stealership is indeed one... call or e-mail scion corp directly if that dealership is trying to screw you over that much.
if you've modified it though, they can't do much and you can just follow the instructions in the thread linked above
12xb
Nov 7, 2015 03:44 PM
daniinpitt
Apr 4, 2015 08:07 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
izzles
Dec 22, 2003 03:32 PM
TheRedBox
Oct 8, 2003 04:25 PM
