TRD Supercharger, worn bearings?
Old Apr 17, 2009 | 09:34 PM
berlwein007's Avatar
Default TRD Supercharger, worn bearings?
Does anyone know the symptoms of worn ball bearings in the TRD Supercharger?
Old Apr 18, 2009 | 03:31 AM
goodguy889's Avatar
sounds like a midget in the s/c.
Old Apr 18, 2009 | 05:24 AM
GammaTNT's Avatar
http://www.youtube.com/watch?v=W7gx7QMwU0I
Old Apr 18, 2009 | 08:43 AM
gompka's Avatar
also if you take the belt off and wiggle the pulley, and it moves even a little bit, that means you need new bearings and/or shaft and bearings.
Old Apr 20, 2009 | 07:18 PM
Thanks for the input, i will check it out.
Old Apr 22, 2009 | 03:08 AM
g2autosports's Avatar
My 1st one made this god afoul loud wine and my 2nd one made this really annoying rattling/clunky sound, then went away and a couple of days later the bearing in the shaft just seized and my engine died in the middle of the road.
Old Apr 22, 2009 | 03:20 AM
GammaTNT's Avatar
it cause your engine to die? I would think the car would still run, with just less air going into the engine
Old Apr 22, 2009 | 03:22 AM
gompka's Avatar
his bearings stalled that means the s/c wasn't spinning at all, that means no air, that means engine dies.
Old Apr 22, 2009 | 05:15 AM
GammaTNT's Avatar
ok, thanks gompka,
now i feel very lucky that my car made to to Ptuning for the sc rebuild.
Old Apr 22, 2009 | 05:17 AM
What he said ^
Old Apr 22, 2009 | 05:23 AM
gompka's Avatar
ok, thanks gompka,
If you needed a rebuild, and your pulley side bearings went out, you'll need a new shaft as well, otherwise it'll happen again. More likely than not the shaft will be damaged, its tolerance is slightly off to begin with anyway. Make sure you have them check that out for you while they are rebuilding it.
Old Apr 22, 2009 | 04:28 PM
GammaTNT's Avatar
i didn't ask them ask them , but my belt is making noise now. i will see how long this sc will last.
How hard is it to install a new shaft.
Old Apr 23, 2009 | 01:06 AM
gompka's Avatar
Not very hard, i'll be making a tutorial soon.
Old Apr 23, 2009 | 01:23 AM
GammaTNT's Avatar
cool, thanks
k1114
43
Mar 1, 2023 03:08 AM
ColonelSanders85
Dec 9, 2020 09:44 AM
rain7905643
12
Jun 13, 2018 05:34 AM
ColonelSanders85
Mar 3, 2015 03:31 AM
Halo19boy
Jan 27, 2015 10:19 PM
