MAF value range
Old Apr 21, 2009 | 01:34 PM
Giupo's Avatar
Default MAF value range
Who knows the 1NZ-FE stock MAF voltage range (voltage to several RMP)?
Thanks
Old Apr 21, 2009 | 01:41 PM
frogbox's Avatar
Voltage is 5v
Resistance is , when measured across pins 1 (E2) and pin 2 (THA0)
13.6 to 18.4 ohm @-20c degrees
2.21 to 2,69 ohm @ 20c degrees
.049 to .67 ohms @60 c degrees
Old Apr 21, 2009 | 01:54 PM
Giupo's Avatar
thanks for you answer,
but I want know the voltage value at several RPM for eliminate the MAF sensor with the Greddy E-manage Ultimate.
Old Apr 21, 2009 | 02:05 PM
frogbox's Avatar
Voltage doesn't change over the rpm range, the air going over the sensor changes the resistance to get the reading.
Your looking at the Mass Air Flow sensor correct?
Old Apr 21, 2009 | 02:31 PM
Giupo's Avatar
Yes, I looking at the Mass Air Flow sensor but for eliminate Maf in greddy support tool I must invoice the volt value at several rmp..
Old Apr 21, 2009 | 04:26 PM
frogbox's Avatar
I don't work with the Greedy Tool , but you could try using the voltage ( 5v) across the board since the voltage doesn't change.
Or you could try tech support at Greedy.
Other than that I wouldn't know. Sorry
Old Apr 21, 2009 | 05:17 PM
Giupo's Avatar
OK, thanks equally
BlingSlade
Oct 19, 2016 12:39 AM
Gigs
Sep 15, 2015 03:54 AM
umnitza
Sep 1, 2015 08:06 PM
mw1957
Jul 28, 2015 06:04 AM
mw1957
Jul 28, 2015 05:31 AM
