alteranate way to fix cel regards to headers
Old Apr 26, 2009 | 03:59 AM
randyhaines32's Avatar
Default alteranate way to fix cel regards to headers
I have a backwoods solve for cel pop out instrument panel it is one screw and pull out odometer this takes 2 min pop out tabs and put ele. tape over cel light this works as well some will say oh cannot diagnosis car but if u got cel on does not make any difference I have tried on my car antifoul straight and L type and changed s-pipe but this here works. buy a programmable scanner if you hear something going on with your motor and save your self the trouble.... test your car every few months to see if a code comes up scanners at autozone 50.00 to 75.00 good investment. and it works if that cel annoys you that much.
_________________
s/c, borla exhaust, cai, w/modified ram air, erz per header, soon change in s/c pulley for added boost
Old Apr 26, 2009 | 01:15 PM
ack154's Avatar
That has to be the dumbest idea to "fix" a CEL ever.
Old Apr 26, 2009 | 01:32 PM
coryjames's Avatar
or you buy a scan gauge so you can clear it or you put your factory header back on and stop the rasp honda bad name giving noise out the back of your car
Old Apr 26, 2009 | 01:36 PM
jct's Avatar
jct
use a band aid instead to cover it up
DJ08tC's Avatar
Yea I defiantly wouldn't call that a CEL fix. That is just a way to ignore it.
Old Apr 26, 2009 | 04:50 PM
BZinn1's Avatar
what header,what s pipe,and what anti fouler.......the L should work just about every time,this is the first one I have seen fail.
Old Apr 26, 2009 | 05:30 PM
ack154's Avatar
^ Unless there's a chance the O2 sensor is damaged?
Has that been checked yet?
Old Apr 26, 2009 | 06:10 PM
BZinn1's Avatar
yeah that is the only thing I can think of other than the spipe issues on some cars where the bung was in wrong place and made the cel.
Old Apr 26, 2009 | 07:01 PM
krazykevin's Avatar
i just kept punching my gauge cluster until the CEL went out.
Additionally, the tach, speedometer and gas gauge doesn't work now... so this is a quick fix to disable your instrument cluster. Enjoy!
Old Apr 26, 2009 | 09:14 PM
SquallLHeart's Avatar
qft.
that's not a fix at all...
Old Apr 26, 2009 | 11:35 PM
Blue_TC_Man's Avatar
and when they hook your car up to the OBD2 scanner they will tell you to replace the bulb cause it is out since the CEL light isnt on, as well as you will be charged a lot if they find out you taped over it
Old Apr 26, 2009 | 11:43 PM
engifineer's Avatar
Yay.. and now when you get a serious code set you wont even know it. Dumbest idea ever for sure.
Old Apr 27, 2009 | 12:56 AM
cburglb34's Avatar
i used tape on my cel for a week because my rear o2 was trashed....
Old Apr 27, 2009 | 01:09 AM
engifineer's Avatar
I can understand (although it is stupid as all getout) how someone with the mindset of "just leave the issue and cover up the warning light" would do something like that. But if you were going to replace the O2 and fix the issue in a week, why on earth would you take the time and effort to put tape over the light? Does the little dim amber light really bother you that much ?
Old Apr 27, 2009 | 01:48 AM
cburglb34's Avatar
well seeing that i have an 08 my cluster is orange and the cel is amber so its a bright contrast...and well every second that it was staring at me made me paronoid...that and the fact that my mom moves my car every morning and just didnt want lip from her
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
xb4lf
Apr 4, 2015 07:15 PM
TinmanTC
Mar 31, 2015 05:02 AM
bktply
Mar 17, 2015 04:50 AM
