My tC won't start.
Old Apr 26, 2009 | 04:52 PM
AnyMeans's Avatar
Default My tC won't start.
Hey, my searcing capabilities are limited on my phone.
My tc won't start. I get power to everything, but it turns over kinda weak and then just clicks. Any suggestions? I don't have any tools down here at school, so I'm going to have to go buy whatever I need.
Should I jump it? Thanks!
Old Apr 26, 2009 | 04:57 PM
DJ08tC's Avatar
If it clicks it is probably the battery so try to jump it.
Old Apr 26, 2009 | 04:59 PM
--Final_Wrath--'s Avatar
sounds like the battery....just get a jump
Old Apr 26, 2009 | 05:26 PM
scikotictc232's Avatar
battery for sure. leave anything on ?
Old Apr 26, 2009 | 05:29 PM
ack154's Avatar
x4 on the battery.
Old Apr 26, 2009 | 06:01 PM
AnyMeans's Avatar
I didn't leave anything on. I still get power to my radar detector and radio. Ill try jumping it in a bit. Thanks.
Old Apr 26, 2009 | 06:06 PM
DJ08tC's Avatar
Well it will still give you enough power for the lights and stuff but not enough to get it started.
Old Apr 26, 2009 | 06:19 PM
rosedaleny806's Avatar
is it stickshift? if so jus push start it, leave it in 2nd have sum1 push the car while ur in it and once u have enough momentum let go of the clutch and give it gas and it will start
Old Apr 27, 2009 | 01:20 AM
SW_08's Avatar
battery x5
Old Apr 27, 2009 | 01:55 AM
Bojan087's Avatar
what he said about push starting it, just dont forget to turn the key to give it power =]
Old Apr 27, 2009 | 04:02 AM
sciontc_mich's Avatar
push starting a modern manual with emissions, not such a good idea. just get a jump start, sounds like the battery doesn't have enough juice to start the car.
Old Apr 27, 2009 | 04:03 AM
DJ08tC's Avatar
^^Yea I was going to say I thought it was bad to push start our cars, maybe I heard it from you?
Old Apr 27, 2009 | 04:26 AM
toeveryhour's Avatar
i had the same problem maybe 3 weeks ago. battery for sure, just like everyone else has mentioned. if it's under warranty, toyota will give you a new battery for free.
Old Apr 27, 2009 | 04:29 AM
never had a problem push starting my car or any other. but idk if its bad for it I jus have to do it cause every1's a dick around here to give sum1 a boost
Old Apr 27, 2009 | 04:46 AM
i kinda remember i might've said it before. I know that it's in many owner's manuals of newer cars. That the emissions doesn't work correctly and not happy things can result by starting the car without the starter (electrically working). computer gets confused if it doesn't have a starting (Reference) point from which to monitor
Old Apr 27, 2009 | 05:40 AM
AnyMeans's Avatar
Ok- I jumped it and it started. 3 hours later it started fine without a jump. Does this mean I need a new battery? I'm going to go get it tested tomorrow I guess. This is on an 05. Thanks for the help guys!
Old Apr 27, 2009 | 06:22 AM
yeah the battery probably has a bad cell in it. a load test would show that the battery is bad. an 05? in 09, yeah 4 years is usually when batteries start having trouble and need to be replaced.
you're welcome.. keep us posted on what happens.
Old Apr 27, 2009 | 12:09 PM
SW_08's Avatar
yea sounds like you need a new battery
Old Apr 28, 2009 | 12:32 AM
Amphia's Avatar
check the battery?
Old Apr 28, 2009 | 02:44 AM
^^ yeah he's taking it in tomorrow. probably will do a load test on the battery.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Luisfc1972
Sep 30, 2015 12:22 PM
OpTicaL
Sep 16, 2015 10:25 AM
