View Poll Results: CAI on turbo inlet
good idea
42.86%
bad idea
52.38%
not sure
4.76%
Voters: 21. You may not vote on this poll
Turbo Tc Topeka Style
Old Apr 27, 2009 | 02:24 PM
topekatc's Avatar
Default Turbo Tc Topeka Style
What do you guys think of the cai setup?
Old Apr 27, 2009 | 02:55 PM
GetIt's Avatar
i give those ******* 4 thumbs down, velocity stack homes.
Old Apr 27, 2009 | 03:18 PM
Ace83's Avatar
Ronin Scion
I have that setup for sometime, i did thorough comparison on it..
here's what I find out..
1. not much benefit from it, the long pipes and bends reduces air flow as compressor sucks air.. not by much compared to regular short ram intake pipe but a considerable amount compared to intake pipeless turbo setup..
2. Difference in intake temp improves but doesnt stay that way very long.. as you use the car longer, the entire pipe would heat up too so after time it would be the same inlet temps as the short ram style setup
I also noticed you have smaller intake pipe near the compressor so more restrictions right there.. with a shorter pipe CAI it might work..
Old Apr 27, 2009 | 03:57 PM
crush02342002's Avatar
I like the style of it but as ace said thers just not enough benefit from it...maybe if you wraped it up in some insulation maybe might make it a little better.
Old Apr 27, 2009 | 03:59 PM
SoFloTC's Avatar
ew
Old Apr 27, 2009 | 04:01 PM
shupes31's Avatar
the distance reduces the effectiveness of it. no go.
Old Apr 27, 2009 | 04:03 PM
Originally Posted by SoFloTC
ew
p-tuning does the exact same thing
Old Apr 27, 2009 | 04:11 PM
Ace83's Avatar
Ronin Scion
it doesnt look bad really, i actually like the look.. but yeah ptuning use it except its a huge 4" and short straight pipe that doesnt give a lot of flow restiction
Old Apr 27, 2009 | 04:29 PM
topekatc's Avatar
so basically no loss but no gain either?
Old Apr 27, 2009 | 04:44 PM
Ace83's Avatar
Ronin Scion
i did not do a before and after dyno.. i did dyno with it and i dont see any huge lag on the powerband and i do notice a little lag when i first installed it, its something you wouldnt notice after few days.. but after i removed the spool was faster, im not sure if its just the sound that made me say that but yeah an intakeless turbo is way better
Old Apr 27, 2009 | 05:23 PM
SoFloTC's Avatar
ok so because p tuning does it, that doesnt mean its the best thing to do? and ptunings is ALOT shorter than that going a different route i believe. spool is quicker the shorter you go, honestly put the filter on the turbo and do a blowby setup..
Old Apr 27, 2009 | 05:37 PM
rhythmnsmoke's Avatar
Music City Scions
ew
Not even close though to this. PTuning's intake is STRAIGHT, with a direct flow from the outside and it's positioned below the engine thus more effectively producing colder temps than this setup I would imagine.
Old Apr 27, 2009 | 05:51 PM
gingles's Avatar
how much longer you got till you finish topeka?
Old Apr 27, 2009 | 06:06 PM
Ptuning_tuner's Avatar
Okay, I thought I'd chime in here since several posts point to our intake design.
As some have pointed out, our intake tube is 4" in diameter and makes a very short and straight shot to the compressor inlet. As a matter of fact, you can probably stick your hand through the intake tube to spin the compressor blade.
IMO, the length and diameter used for your CAI will more than likely negate any of the benefits of a CAI filter location. Think drinking a milkshake through s soda straw.
With that said though, I do have to say that you did a good job with making your set-up look clean. Good luck with your build.
- Toan
Old Apr 27, 2009 | 07:14 PM
Ace83's Avatar
Ronin Scion
yeah it looks like you have a 2.5" intake right after the compressor inlet, i used full 3" pipe a noticed a bit of lag.. you might feel the restrictions even more.. but if you wanna stay with that setup, its not a problem, you're not gonna lose tons of HP
Old Apr 27, 2009 | 08:23 PM
topekatc's Avatar
setup will be done tonite minus a few minor things. intake is 2.5 to 2.75. My ic piping has a blow thru maf mount but i think it is too high to get an accurate reading
Old Apr 27, 2009 | 08:26 PM
CarbonXe's Avatar
The temperature difference is completely negated when the air is compressed.
Old Apr 27, 2009 | 08:28 PM
ew
I was commenting on the "style"...it just looked pretty clean like the p-tuning intake pipe. Dont get ____y on me Trav
Old Apr 27, 2009 | 09:15 PM
Music City Scions
ew
I wasn't ...... It's just that when you read the description of Ptuning's intake about it being straight, less curves being a direct flow to the compressor...etc, couldn't help but to think this guys setup is not as efficient. To many bends and length of the tube.
Old Apr 27, 2009 | 09:28 PM
topekatc's Avatar
there are actually only 2 bends
