Automatic Door Locking and Unlocking
Trying to set my locks to where they lock with speed and unlock with the drivers door.
Following the steps
ON position
Neutral
Holding down unlock / lock for 5 seconds within 10 seconds of turning on
Not working. Any input?
Following the steps
ON position
Neutral
Figured it out, you have to cancel the current mode, THEN program the new mode.
The door lock with speed is nice, about 13-14mph. If you stop, someone gets out, then go again, the door relocks.
Unlocking with drivers door is nice, because it only unlocks the whole car if its turned off, so if you get out and leave the car running, the drivers door is the only one unlocked.
In the stock mode, the lock with drive was nice, but IMHO unlocking all doors in park is unsafe.
Its in the front part of the owners manual, there are steps for setting lock mode to either lock the doors in any gear other than park, or lock them over 12 mph.
Unlock modes are either when its put into park, or when you open the drivers door when the car is off.
To turn lock with gear selection on/off:
turn key to on
hold down the lock button on the drivers door for 5 seconds, then release.
to turn on/off lock with speed:
turn key to on
move gear selector to neutral
hold down lock for 5 seconds
To turn on/off unlock with gear selector:
turn key to on
hold down unlock for 5 seconds then release
To turn on/off unlock with drivers door:
turn key to on
place car in neutral
if the code takes, the locks will cycle after you release the button. Once you turn the key to on, you have 10 seconds to press and hold the lock/unlock key.
Also, you have to turn off whatever mode you are in, before you can turn on the new mode. This was my first mistake, and I could not get anything to change.
turn key to on
turn key to on
turn key to on
turn key to on
Or, just go to dealer and have them hook up computer and do this for you. supposed to get this one time for free, i have mine where when i turn off car, and open just drivers door, only that door opens, and it locks when i hit 11ish mph. i also turned off the beeping for the seat belt, only flashes. you would be amazed what options you can mess with.
Im surprised they would do it for free, most dealers charge for stuff like that. There is also the trouble of taking it in, when I did it in my garage in 5 minutes.
Andrey, did you turn off the current setting (lock and unlock with gear selector) before trying to turn on the new setting?
You cannot jump from one feature to the next, the current must be turned off first.
I tried to do the steps for turning off the locking when u shift out of park -
turn key to on
After I held the button for 5 seconds nothing happened...so I tried all of the other things on there to see if I would get any confirmation for ANYTHING but nothing happened.
I need to get my hands on a manual, the beeping with the seatbelts is annoying! I put my backpack on the passenger seat all the time, and it's heavy enough to think that there is someone sitting there.
turn key to on
Locking linked with shift:
All doors lock when gear selector is moved out of P position
Locking linked with vehicle speed:
Doors lock when speed is over 12 mph
To select or cancel vehicle locking linked to gear selector:
Close all doors and turn switch to on
leave selector in P position
Within 10 seconds of turning ign on, hold drivers side lock switch for 5 seconds and release
To select or cancel locking linked with speed:
Put selector in N position
Unlocking linked with shift position:
All doors are unlocked when selector is in P position
Unlocking linked to drivers door:
All doors are unlocked if drivers door is opened within 10 minutes of shutting engine off
To select or cancel vehicle unlocking linked to gear selector:
Within 10 seconds of turning ign on, hold drivers side unlock switch for 5 seconds and release
To select or cancel unlocking linked with drivers door:
Originally Posted by AndreyCo
Just tried it again, worked perfectly! Not sure what I was doing wrong the first time though.
What are the instructions for making the seatbelt not beep?
wonderworm
11-19-2023 01:44 AM
Inazuma
20
05-03-2023 01:58 AM
