Transmission stuck in parking...
Old Apr 30, 2009 | 12:31 PM
barbasyan's Avatar
Default Transmission stuck in parking...
I tried to drive my 05 Tc for a ride this morning and opps... I couldn't move a **** from P. Parking brake was on before. I don't know if it matters but few hours prior to that I was changing my tail lights. SEL isn't on - no messages what so ever. Anyone has any ideas? Does it have anything to do with fuses? TIA
Old Apr 30, 2009 | 12:33 PM
ack154's Avatar
Are you pushing the little button on the shifter to move it?
Does the auto tC have one of those? I haven't driven an auto one... just guessing.
Old Apr 30, 2009 | 12:40 PM
bdis3's Avatar
Steering wheel locked?
09tC_CB7's Avatar
Are you parked on a steep incline? That can put an auto transmission in a bind and now allow it to move from park.
Old Apr 30, 2009 | 12:55 PM
SATownScion's Avatar
isnt there an override button hidden under a little tab in the center console?
Old Apr 30, 2009 | 01:04 PM
09tC_CB7's Avatar
That is for when the battery is dead. I guess it couldn't hurt.
Old Apr 30, 2009 | 01:15 PM
barbasyan's Avatar
Add on - brake lights don't come on when I'm pushing down the pedal. I guess this is the reason of transmission blocking itself?
Old Apr 30, 2009 | 01:18 PM
could be, if the car doesnt know that the brakes are on, it wont release the shift lock. check your fuses and your wiring of the brakes lights. make sure the connections are sound as well as grounds.
09tC_CB7's Avatar
Yup. It probably doesn't know that you have the brake pressed and won't allow you to shift out.
Or you tail lights are broken or not installed correctly.
Old Apr 30, 2009 | 01:22 PM
barbasyan's Avatar
Does anyone know a fuse location for brakes?
Old Apr 30, 2009 | 01:24 PM
barbasyan's Avatar
TAILS are stock - I pulled them out to sand down a bit then put back on. Dunno what happened
Old Apr 30, 2009 | 01:25 PM
i would think the box under the hood
Old Apr 30, 2009 | 01:28 PM
barbasyan's Avatar
that's right ... but which one in it - that's the question. dont feel like pulling all of 'em out...
Old Apr 30, 2009 | 01:29 PM
look under the cap, it has a diagram
Old Apr 30, 2009 | 01:34 PM
turn signal and hazards are under the hood while tail lights is under the drivers side dash. both are 10amp fuses
Old Apr 30, 2009 | 01:53 PM
barbasyan's Avatar
fix it - pin 9 driver's side dash. Everyone thanks. SATownScion you are the man!
Old Apr 30, 2009 | 01:57 PM
no prob dude, glad you fixed it
Old Apr 30, 2009 | 10:52 PM
Hyghgynx's Avatar
When you blow the fuse. You can't engage the shifter. You can 'override' the lock by opening little tab
by the shifter. (Although I would not advise it because you will have no rear brake lights!) This is also
in your Manual. Glad you fixed it. Next time, do what I do; working on anything electrical, pull out the
fuse(s). Makes life A LOT easier.
Old Apr 30, 2009 | 11:53 PM
BZinn1's Avatar
unplugging battery is always a great idea in a 12v system if you are pluggin in or taking off anything.......DC currant likes to short out very easy.
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Oct 21, 2015 02:21 PM
Pkdust
Oct 20, 2015 04:27 PM
BlingSlade
Sep 5, 2015 08:52 AM
paisatronix
Sep 5, 2015 04:13 AM
